unplugging wiring harness
    just a quick question, how would you unplug the red covered wiring harness on the passenger side of the engine bay?
    is there a button like the other plugs or does it simply unplug?
    ill see if i can get a pic
    i think you just pull it apart, its been awhile. later.
    Avoiding dirt at all costs
      you need to pry the rubber cover back far enough to get to the button, then its like a regular connection...
        thanks i got it
        oh and there is like one sensor right under the mani but above the oil filter...i took off the rubber housing and does anyone know what kind of mm wrench that takes? it is like a 23-24?
          F22A = Oil Pressure Switch
          H22A = Knock Sensor
          Remove the oil filter and use an adjustable wrench to remove it.
