Originally posted by 4CYLPOWER92
the thermostat closes and lets the motor run without circulating coolant, so it heats itself up with no cooling ability, and it only opens and lets the motor cool down if its getting TOO hot. thats how it regulates engine operating temp.
if hes sitting still, the radiator is getting no air and isnt cooling down the coolant, so its basically as if the motor is running with the thermostat closed, and the needle will rise and itll run warm. once it gets too warm, the fans kick on, creating air movement across the radiator to cool things down.
the fact that his heat blows cold and his idle never drops shows that the coolant is staying too cold... a sign that its passing through the radiator even when it isnt supposed to...
