why in the world would a fully tightened timing belt creep to the left and get chewed up by something or other? It started last night, I replaced the belt this morning, by the time I got home at the end of the day (19 miles) the belt was about 2 cm wide.
eating timing belts
well look at it while its running with the cover off...and then you will see.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
something under there is hitting it probably...go check...What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
i was just about to say that, not having the tensioner on the peg and tightened down, the tight belt makes the pulley go angled and it lets it walk off, and will make that happen. glad you figured it out.
