eating timing belts
    eating timing belts
    why in the world would a fully tightened timing belt creep to the left and get chewed up by something or other? It started last night, I replaced the belt this morning, by the time I got home at the end of the day (19 miles) the belt was about 2 cm wide.
    what do you mean 2cm wide? And are you sure its tight? If its not tight it will flap and hit the cover.
      well look at it while its running with the cover off...and then you will see.
      Retro!
      Hater
        What I ment by 2cm wide is it looks like this now:
        and yeah, it's tight
          aftermarket cam gears FTL?
            What is FTL? Those are stock cam gears.
              something under there is hitting it probably...go check...
              Retro!
              Hater
                I got it. The tensoner was able to rock back and forth because it wasn't on the little hingy peg deal.
                  i was just about to say that, not having the tensioner on the peg and tightened down, the tight belt makes the pulley go angled and it lets it walk off, and will make that happen. glad you figured it out.
