Where does this wire connect to?(pix)
    I actually noticed that about three months ago, when i removed my short ram to get to a coolant hose in the back of the block.It comes from my abs motor box, but don't know where its suppose to connect to.Abs works fine btw.
    I searched all around the area but i just cant find anything that would connect to it,any inputs?
    ILBB
    People I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
    Mk3 Supra Member #2
    Originally posted by DarkShadow707
    The world needs to be reset.
    Any info?
    ILBB
    Mk3 Supra Member #2
      Bump, plz can someone trace that wire form their abs motor box and see where it goes?i serously searched everywhere arould that area and cant find where to connect it...
      Mk3 Supra Member #2
        going to check my car right now...
          i do not have that wire. i just checked my 93 SE with the same ABS system. I have the same harnesses that you do too, but no stray wire. Can you take a pic of where it connects to? My car is an auto so that might have something to do with it...
            damnit i would but my sis took the digi cam at work.I did some further investagation though, I opened up the box try to see were it is connected too.Well in that fuse in the bottom middle of the box, the one that has three wires coming out of it, on the wire in the middle (black/yellow) its spliced and there and then the black and white wire just connects to the fuse.i know its confusing.it doesnt look factory at all, were its spliced its just covered with electrical tape.
            Mk3 Supra Member #2
              ya that's what I thought. Someone prolly spliced into the ABS box to get +12V for an aftermarket alarm system.... not a smart idea since screwing with your ABS can get u killed. derrrrrrrrrrrrrr
                its deffinatly not factory, just looking at it it looks like the first owner fucked with it...Oh well, thats one less thing i have to worry about...Thanx for the help thogh
                Mk3 Supra Member #2
                  i like to cut mystery wires
                    me too j/k
                      Hows that? If your ABS system quits working, your brakes will function as if you never had ABS. I haven't died yet without ABS on my junk.
                        I was on the hiway following some one to go to a party, well he decided to take the exit with out using his turn signal.I slemed on the brakes so i wouldnt miss the exit, If the abs was not workin, i'm pretty sure i would of spun out of control.ABS
                        ILBB
                        Mk3 Supra Member #2
