now this problem has been happening for a long time now,its not just becuase its winter,and also it does not happen all the time just once and awhile.the problem is when i turn the key to start the car up it wont do anything not even click all the guage cluster lights light up like they should and then i'll let off the key and try again and it starts right up,i have a new battery,and i dont really car that it does this because it always starts on the second try,i was just curious to what this could be.thanks
starting problem
that click..is it associated with the check engine light...when the check engine light goes out, you hear a click normally yes?
if its not clicking and thats the click you are talking about...it is the main relay
here is a helpfull thing to replace it
http://www.cb7tuner.com/vbb/showthre...=&threadid=310
if not then let me knoWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
my car has been doing the same thing, turn the key, its like the starter isnt even connected.... turn off and on again, and the car starts fine. i dont believe i heard any click either... i thought my starter was flaking out.
then wont that be the starter relay? thats what happend to me, replaced the relay and it was fine.....
haha i remember my shit wouldnt click...i was pissed cause i knew it wont start....i bought a new one and put it in and it worked like a charm...but i believe u can open it and re-solder the connectors that are worn and it will work for another year
there is a way that helms tests it...i forgot thoughWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
