I got a set of strut rod bushings from Energy suspension and Prothane. Neither fit. Both front and back one were abou 4 to 5 mm too thick. Both were exact same just one from ES adn other from prothane. Am pretty dam sure they are not for strut mount. As they have separate ones for that. Anyone Else have this experience? I am going to order some mevotech supremes as they come with new hardware and seem thru pic to be right size.
Front strut rod bushing from ES and prothane did not fit?
I suspect your old ones have taken a compression set (they didn't rebound to as thick as they were originally) because of age. Will either set actually go on the rod over the sleeve and in the pockets in the cross member? If you can install them and the nut tightens the washers down onto the sleeve, I would go ahead and use them.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostI suspect your old ones have taken a compression set (they didn't rebound to as thick as they were originally) because of age. Will either set actually go on the rod over the sleeve and in the pockets in the cross member? If you can install them and the nut tightens the washers down onto the sleeve, I would go ahead and use them.
Is this with or without tightening the nut on the forward end of the radius rod to compress the bushings?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
you also made sure to install them the correct direction too, right? one half is fatter than the other. And like fleetw00d said, you tightened the main nut all the way first?
Originally posted by cp[mike] View Postyou also made sure to install them the correct direction too, right? one half is fatter than the other. And like fleetw00d said, you tightened the main nut all the way first?
Originally posted by zedjr10 View PostYes installed in right direction. I did not try tightening the main nut under bumper first. I just thought no way will this result in almost a half a centimeter. So are these new bushings supposed to be fatter like they are? The rubber ones from moog and mevotech seem smaller than the poly ones? Their going to compress that much?
Originally posted by cp[mike] View PostYou'd be surprised. Put the bushing halves back-to-back, and compare their height to the metal sleeve that goes thru the center - the bushings will end up compressing down to the length of the sleeve before the hardware bottoms out.
I went to part stores to compare mine and ones they had. Same exact size. I never thought they would compress that much. They are already so stiff compared to rubber.Last edited by zedjr10; 05-27-2018, 08:41 PM.
So you got it back together?
Maybe it's time for me to replace mine!90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
I feel your pain man I had the same problem with how thick new bushings are..& I was just using replacement Duralast rubber ones not even polys. You just have to kinda force it in place since they are obviously thicker than the ones you were running. They will definitely add driving improvement. Less slop.Keep Pushing..
