Hello guys I did some surface searching on a few routes to overcome this hurdle. I have a chipped p72 with stock h22 map on it. Ran like normal until motor spun a bearing. I bought another h23 block with h22 head and had both rebuilt to or specs. Installed motor and now I have a CEL code 03 MAP sensor. What caused this to happen? Thanks guys! BTW my mechanic is referring me to get a custom harness from rywire or monotech..
Dying for a harness
is that the only CEL you're getting? maybe you mixed it up with the plug for the TPS.
or, you used to have the Accord MAP sensor hooked up, without realizing it. Because the car won't run without the MAP. The stock map sensor is mounted to the firewall (inside the black box) and is connected to the motor via a Vacuum tube. I think maybe when you hooked up the new motor, the MAP tube got hooked up to the wrong nipple on the manifold (or not hooked up at all?)
Originally posted by cp[mike] View Postis that the only CEL you're getting? maybe you mixed it up with the plug for the TPS.
Originally posted by deevergote View PostSounds like you need to address your wiring. Wire it correctly, and use a map sensor that you know works. Anything else is a halfassed solution, and you're not likely to find that here.
Originally posted by deevergote View PostThat seems to be the only option. If plugging an important component in causes problems, there's definitely something wrong, either damaged or misplaced, in your wiring. It's tough to diagnose it any further, since custom work has been done.
Check your vac connections as well, as cpmike mentioned.
