Good Morning,
I had a question about my rotor. I had bought the economy Brembo rotors and pads over a year ago, because I was tired of buying the cheap crap that would warp. I noticed last night I have a groove in the center of my rotor and I was wondering what causes that wear? Brake pads/Rotors/Calipers are good. No shuttering when braking or noise. I wasn't sure what was causing the issue so I read up a little and found different answers and would like the forums opinion on what could be causing the groove.
I read it was hooking, and it's normal wear? That is could be something was wedged? Bad wheel bearing? Stud in brake pad, (not worn tho) so I'm confused to what could cause the groove?
== lip of rotor
||| groove
==-- hub
||| groove
== lip of rotor
||| groove
==-- hub
||| groove
