I have recently tore my motor apart and now putting it back together. My question is, do the bearings and rod ends/caps go in a certain order? I kinda lost track after tearing into a lot of things and moving stuff around. I purchased new bearings,when me and a buddy torque them down with the correct specs, the crank seizes. These bearings are the first rod cloesest to the pump. It's where the crank wont turn unless a lot of force is used. We didn't try and force the crank to turn, I didn't feel like messing up new bearings. The bearings/rods are lubed and clean, nothing chunky in between. I've searched the forums and haven't found anything on the order the bearings or rod caps go. Can someone please lead me in the right direction?
Please and Thank you!
