Snapped bolts in my head..... 60k miles ago
    2 years ago I was doing my valve seals.
    I was using a ft lbs torque wrench to approximate in lbs.
    Things happened quickly, and I ended up going further than I meant to.
    I heard a terrible screeching noise. Panicking, I ignored it and put everything back together.
    The other day, I did my valve cover gasket, and adjusted the valves.
    I touched the bolts along the back row, and this one was loose. I used a magnet to pull it out.
    Cylinder #3.
    MRT
    sneaky motherfucker
    Your an idiot lol. If I can't see it it doesn't exist! Since there is no clamp load on it drill the center and reverse the thread on the inside to pull it out. Lucky you haven't had any problems.
    '93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
      Originally posted by domesticated View Post
      Your an idiot lol.
      Ahem. "You're."
        Currently, my plans are to just leave it and hope I never have to remove it. It broke off right at the threads, so It'll be loads of fun getting it out.
        MRT
        sneaky motherfucker
          Originally posted by mtnbikaah View Post
          Ahem. "You're."
          I was on my phone....
            no worries.
            It was just ironic.
              It shouldnt go anywhere.I did this to 3 out of 4 of mine.Still broken
                Then you need to check your tube seals, the bolts are there to seal the back part of the seals, as well as secure the cam.
                Your phone only does what you tell it to do.....
