Fix Joey's Car Month continues....
So 2 weeks ago I was in the drive thru and I notice what looks like steam coming from my car, but I was behind a V8 SUV so I'm thinking it's his exhaust gas. A week later, it happens again after I shut off the car. The steam only comes off for about 5-10 seconds, then it's gone, so I can't even pop the hood in time to see where it's coming from. Based on the sound I think it's the hose directly connecting to the radiator but I could be wrong. Engine temps still showing normal at this time. Then a few days later, the engine overheats excessively fast after about roughly 3 minutes of driving. I pull over and add about a quart of coolant. It overheats again, but very slowly with the needle never reaching the top. Then, as I pull into walmart to buy more coolant, temps drop instantly. I added another 3 quarts of coolant and for the next week, everything is fine again. Today, I notice the temp gauge running very slightly higher than normal. It raises again slightly but only till about 3/4ths of the temp gauge itself; with the wind coming through the bumper keeping temps normal. I'm going to add another half a gallon of coolant tonight, but I can't/won't buy coolant once a week.
I've continually went under the car and can't find an ounce of coolant leaking anywhere. So I'm thinking something is failing. Headgasket? Thermostat? Water pump? Can radiators cease to work even if there's no leak? I'm taking the suggestion of doing a coolant system pressure test, but beyond that I'm clueless.
