Groaning noise as I turn and accelerate.
    My cb likes to groan as I turn from a dead stop and accelerate. It gets louder the more gas I give it, its like a loud, mechanical/metalic groaning noise. Kind of like metal on metal, but its not a high pitched noise, its a very low pitched, loud groan. Sounds like its the suspension or brakes. Maybe its the driveaxles or the brake rotors rubbing something, I don't know. I know its not the power steering system, I fixed that... It started happening after I put the the engine back together... Plz help.
    “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
    ― Jeremy Clarkson
    What I hear: "Hi guys, I've messed with everything that could be making this noise. Please help."
    Have you checked your ball joints?
    MRT
    sneaky motherfucker
      I did an H22 swap after that I had A grinding sound / groaning noise, I chased all kinds of things down that I thought it could be. It turned out to be the intermediate shaft bearing. I pulled the intermediate shaft and the bearing had play in it.I could wiggle the bearing end it moved about 1/16. I went to the salvage and pulled one off of a 92 CB the bearing was solid, I went home and installed it and no more noise. I chased this for about 5 months hope this can help. Good luck.
        I have brand new ball joints, outer tie rods, and upper control arms in it. Update: I took it for another drive and noticed it starts to do it also when i'm accelerating from a dead stop over a hill. Not nearly as bad as when I turn though.
        ― Jeremy Clarkson
          I don't have an intermediate shaft on my automatic, autos only have a long axle on the driver side. So that might be out of the question, unless there is a bearing on the axle that would make the noise.
          Any other possibilities on what it could be?
          ― Jeremy Clarkson
            could be wheel bearings, could be the bearings or something in the steering column.
              x2 for wheel bearings
              A&P-IA
                X3 on the wheel bearings.
                Which side does the noise sound like it is coming from?
                You said it's louder when you make a turn. In one direction only....or both?
                  It will actually do it in a straight line if I am going over a hill from a stop, but it only does it partially, when gravity makes it pull downward it will make the sound but it is never as constant as when I turn and accelerate. Its just partial. It also does it when I turn in both directions too. The noise also doesn't happen all the time, it seems on hills is when it does it most.
                  I actually heard someone say it could have been the dust plate rubbing the rotors, idk. The bearing were working fine before the rebuild, I don't know what I could have done to ruin them. The car still glides well. How can I test if its the bearings?
                  ― Jeremy Clarkson
                    if the power steering fluid level is low, it will make a strange noise similar to what you describe. later.
                    Avoiding dirt at all costs
                      The power steering works perfectly I just fixed it it was overflowing and letting air into the system. Now it works great. So Its not that.
                      The sound I am describing is a semi-strong, vibration type sound which I can actually feel underneath the car.
                      ― Jeremy Clarkson
                        Can you feel it in the pedals or the steering wheel or both?
                        '91 EX 280,000 || '90 LX 330,000
                        _____(me)__________(wife)___
                          Its in the steering wheel if anything. But it feels like the wheels.
                          ― Jeremy Clarkson
                            have you checked you rack and pinion? my ce1 is making a similar sound. just going to wait till taxes come to deal with this.
                            92 LX N/A rust bucket restoration RIP
                            91 DX Coupe to 9293 EX Coupe restoration
                            funds for swap:$000.00
                            Bought from:HondaFan81=My current CB7 DD ,CB7_Sleeper1 Koochologist Tommi mtnbikkerkid33
                            Traded with: Wed3k
                              No but I doubt its that. Now I'm getting the noise while driving in a straight line from a stop. I can hear it creaking and moaning.
                              ― Jeremy Clarkson
