ok so i replaced my f22a1 with another f22a1 with less mile and i did a wire tuck and i got it running and now i just found out my headlights are not working i checked fuses none are blown any ideas?
Headlights wont come on :/
That's really vague.
Check your bulbs.
Check your wires.
Check your connections...
BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
Originally posted by 92a6 View Posti did a wire tuck ... my headlights are not working1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Originally posted by wildBill83 View Post$10 says the problem is in your wire tuck... Did you test the wires before bolting everything up?
Originally posted by 92a6 View Postok so i replaced my f22a1 with another f22a1 with less mile and i did a wire tuck and i got it running and now i just found out my headlights are not working i checked fuses none are blown any ideas?
Which one doesn't it have?
My 5.7 LS1 Holden Ute
Then you have a cold solder or bad connection somewhere.1993 SE Coupe MRT - 1992 LX Sedan MRT
If you hadn't fucked with the wiring and it was stock then we could possibly help you more with the problem.
I am assuming your lights worked fine before the tuck, so yeah like wildBill83 said it most definitely something with the tuck itself.
You are going to have to go through all of your wiring and make sure everything is everything because apparently you've done something wrong there...
Originally posted by 92a6 View Posti had to extend the headlight wires for the tuck theres no way around that1993 SE Coupe MRT - 1992 LX Sedan MRT
Originally posted by wildBill83 View PostStart diagnosing there then ... See where the power stops at and that is where it is broken.
Originally posted by cb7rush View PostMost likely its in the wire tuck. And if not it could be your headlight switch or relay
Originally posted by 92a6 View Posthow can i see if the relay is bad cuz i couldent pull it out of the fuse box
IDK, that might be your issue. When you rewired everything you might have blown the relay.
