Vehicle Speed Sensor!!!!!!!!!!!
    ok i am no newb lol. my speedometer doesnt work and i have put three vss in the tranny and no luck. still doesnt work. the three i put previously worked on other cars so its weird. ask cpmike he was helping me but he had to go to school so i couldnt get everything done.
    so i have tried 3 different ones and they havent worked. wut else should i check. and this happend way after i did my swap. my swap was done in september and this just happened this week.
    let me know wut u think
    mauricio
    prob wiring http://www.cybertrails.com/~bestinth...tLocation.html
      Check the connector on the drivers side strut tower by the resistor pack. If you are auto it'll be like 5 or 6 wire, if yo uare 5 speed it'll be 3-wire. The 3-wires are the VSS. Make sure that connector is snug.
        jose i checked the 3 wire clip on the driverside near the resistor box. and nothing. still doesnt work. thanks for the tip.
        and the link. prolly tomorrow i will look at excatly is wrong with it.
        just asking if it isnt the wiring do u guys think it could be something in the tranny. well where the hole is for the vss?
        thanks
        mauricio
          It's not likely that there's a problem in tranny. Does the CEL turn on?
            maybe the shaft in the tranny is broke or is not sending anything.
              yea the cel turns on #17 so i cant engage vtec lol. didnt check it out today cuz it was a mad storm here in jersey. to much wind and snow/rain/slush.
                Are you changing the complete sensor with the gear on it or just to top electircal part?
                  I have the full speed sensor if you need it. blah elt me know
                    the full speed sensor. three of them to be exact. one from a h23 tranny. 93 ex vss(5psd) and a 92 lx vss (5spd)
                      Jack the front of the car up and secure it on jack stands, put the tranny in neutral, get a volt meter, connect the negative lead to pin A26 on the ECU harness and the positive to pin B10 on the ECU harness, block the right front wheel so it cannot turn and slowly turn the left front wheel. The voltage should pulse between 0-5 volts. If it doesn't check the wiring, connections, and etc. It could be the speedo driver in the transmission but I've never seen one break.
                        damn i hope its nothing in the tranny. will do jose. just need the snow to go away.
                        thanks alot
                        mauricio
                          Hi,
                          I was just wondering what ever came of this? Did you get your problem fixed? I'm having the same problem - started after the f22a1 < f22A swap.
                          Info is really appreciated by me!
                          - Zipcreature
                          Awesome!
                          CB7. F22A. 5spd. CB7. Exedy. Chromoly. AEM. DCSports. Apexi. Progress Group. AGX. Suspension Techniques. Viberant. Goodridge. Facebook
                            which one is the A26 and the B10?
                            is it only the left front wheel that sends the voltage?
                              btw mauri found that one of the VSS wires got old and cracked in half... making it not work at all
