ok... new vtec sol(282.00)... head rebuild.. new everything... i rewired vtec twice!!! actually more...
followed these instructions...
Pin locations for OBD-1 ECUs:
- Vtec solenoid: Pin A4-forget which wire color this is
- Vtec pressure switch: Pin D6-baby blue wire
- Vtec pressure switch Grnd-black wire.. i grounded it to three different locations checking to see if that was it.. no go.. i rechecked to make sure i had the pin locations correct and i did..
the last thing i can think of is the ecu.. MRX chipped this ecu and did a vtec conversion to it as well.. it threw a vtec sol CEL(7) within a few seconds of revving.. also the connections are electrical taped up.. meh.. someone forgot to bring down their soldering gun(not u antoine) lol.. i dont think that would have an effect on it engaging thou..
P.S
- Knock sensor: Pin D3-disabed in uberdata
- Secondary Intake Solenoid: Pin A17 (Connect Black/Yellow wire on solenoid to switched ignition, the other to pin A17)-run of vacumn..
thanks j00
P.S
thanks j00
