So I'm looking into the pro1 cams from skunk, but was wondering which valvetrain would be best to use for this setup? I'm sure skunk2's pro series valvetrain would work best since they're made by the same company, but I was leaning towards a supertech valvetrain set up. However, if a pro series valvetrain is going to help my engine last longer than I'll go that route since I want it to last as long as it can, but I've heard good things and a lot of people who run skunk2 pro1 cams with a supertech valvetrain.
Skunk2 pro1 cams w/ what valvetrain
skunk2 valve springs = death to rocker arms and cams... id stay away. they make nice cams tho
Originally posted by Restless View PostThanks for the advice quickangel, I'm going to check out Bisimoto's valvetrain right now and how does skunk2's valvesprings mess up the rocker arms?
also +1 on what you mean by "valvetrain" - i assume you mean springs+retainers, at least... of course you can do valves as well but that requires taking the entire head off.
Originally posted by Sarthos View PostWhen you say "valvetrain" are you talking about upgrading your springs? Or springs and retainers? Or valves? Or what exactly all are you including here?miss my turbo cb7
Okay I never knew the actual term of valvetrain. When I used the word valvetrain I meant valves, valvesprings, retainers, and whatever else is included in rebuilding the head. Also, thanks for the info cpmike much appreciated. I'm almost certain now I'm going with supertech, but may choose bisimotoLast edited by Restless; 03-16-2011, 02:29 PM.
