Map sensor..location?
    Welp to start off i proceeded to finish taken the intake mani off to install the bisi IM gasket and port the mani(and let me tell you its not like a damn D series mothers stuffed in there like a 747 in a 2 car garage.Mostly the back T-bar bracket was the pain to get to.).Anyway got it off in about 30mins in the rain finally...Welp i notice my map sensor is zip tied to the fire wall(notice that when i got it) but the vacuum lines go no where.Arent they supposed to be tied into the TB?ik most firewall maps are or is it tied into the shit canester aka vacuum canester located on passenger side lower firewall.Car is f22b1 swaped and i do not see any vacuum fittings left to plug the lines into on the mani nor tb and it never set a code for the map.Any ideas?
    02 Crv
    Are you talking about the thing directly behind the intake, mounted on the firewall? IIRC it has two vacuum lines and some lines going to it.
    Is that the MAP sensor?
    MRT
    sneaky motherfucker
      Found out where it needs to go also the EVAP sensor aswell is on the firewall neither was connected.Never seen a evap on the FW always have been located on the driver side of the IM guess not on the b1.Glad thats cleared up simple fix.
      02 Crv
        No map sensor says it on the sensor.It was to just pluged up and ziped to the firewall.I just looked at it real quick before i put this on here.The one with 2 lines exiting the sensor is the purge sol.So fixn more things along the way glad i caught it now they are simple fixes.
        02 Crv
