need some help. check this out.
    I drove this morning and i heard some loud clunking noise coming from my drivers side.once i stepped on th break it stopped.i put it in reverse and it sounded like metal to metal were rubbing hard.Took the drivers side rim off looked underneath the car and found this.
    This pic you see something scraped inside if rim.
    closer look
    also found this.not too sure how long i have been driving like this.what is this called.racket pinion,drive shaft.or.......
    Guess who needs new tie rods?
    You do!
    That could also be the rack you're seeing inside the boot.
    It's not the driveshaft. The axles connect to the center of the rotor. See the giant axle nut?
    Look for something attached to the steering knuckle rubbing on your tire.
    My friend had an s10 where the caliper often became unbolted and would jump up and down.
    MRT
    sneaky motherfucker
      so i just need a new tie rod and problem fixed.
      should i also replace the passenger side.
      what about the boot that is broken.
      i was told it has to be dry in there and not wet.
      u guys think i have to replace my
      rack pinion.Thanks
        hey man i kno ur problem right off the bat...when was the last time u changer ur brake pads?well this same thing happened to me one of the bolts that hold the brake caliper to the knucle it gone..look behind the brale caliper and see ifu see a holethat looks like a bolt would go into.....or ur rim is badly bent but i highly dout that cause we would see it..id be that bad
        my new turbo build
          Thanks alot man.ill check it out in the morning.
            that would be my guess to. if it where your ti-rod sticking that far out you would not have any steering because it would be busted.
            IT IS WHAT IT IS
              wow i was sooooo tired when i wrote this!!
              my new turbo build
                Yup,one of the bolts was gone.Then i tried to tighten the top one and it just turned and turned.There was no more thread so it wouldnt get tight.Nedd to hit the junk yard so i can get the bracket that holds the break pads.Know need to check the other side.Need to buy a rebuild rack and pinion.Thanks again for the replies.
