Wheel speed sensor
    Wheel speed sensor
    Where can I find a cheap ABS wheel speed sensor?!
    Everywhere I look they're all over 150+ dollars for our gen cars..
    ABS light is annoying...
    Yes my name is Dang, Don't use in vain
    1992 Honda Accord EX (Coupe/Bordeaux/Auto)
    1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
    2008 Honda Accord EXL (Coupe/SanMarino/6spd)
    http://www.car-part.com/
    that's where i got mine!
    ended up coming from a junkyard in NC.... shipped it to me in MA.
    dont recall the price. helluva lot cheaper than new!
    92ex CB7<-SOLD 93ex CB9shiftingshift73C10
      Yeah just get one from a junkyard. Although your taking a risk its better than $150 for a new one.
        If you unhook your ABS that has nothing to do with your speedometer not working right?
        Slamage is worth the Damage
        Originally posted by crazymikey
        "Yes, we did officer. By the way, your eyes look a little glazed, did you just come from the donut shop?"
          No. there's a different sensor in the transmission for that one. VSS
          the ABS one just monitors every wheel in a slide so that it can control them independently.
            Before you get new sensors, take a look at the magnetic toothed ring. I bought new sensors before bothering to check the ring.
            MRT
            sneaky motherfucker
              What should I check for?
                ive got 3, i lost the driver side one and then decided to removed ABS in order to get rid of the light and system, it depends on which one you need but the only reason i saved the sensors when i removed ABS was for occasions like these.
                Engines hate me... thats why they commit suicide
                  I misspoke, I changed my sensor and the problem moved to a different wheel. I'm going to change that wheels sensor and see if the problem goes away.
                  However: When I looked at mine I did see some corrosion filling the spaces where the teeth should be. I have a feeling that once I do the other wheels sensor It will throw a code for the toothed ring.
                  MRT
                  sneaky motherfucker
