starter wire caught fire
    the starter wire boot that went over the starter terminals caught fire today but i cant determine what caused the initial spark.
    the wires are hella old and the starter is from the junkyard so both conditions are poor.
    I'd be more inclined to look for a thermal cause. I've seen jumper cables melt the insulation right off of the copper, but I've never seen a spark catch the rubber on fire. with everything being old, it's possible that the resistance just caused enough heat to burn it up. How long have you been using it?
      loose connections can do that. arcing and what not. Loose Wiring that is chaffed thru and grounds on metal anywhere can also do that
        that's a funny sig.
        Yes my name is Dang, Don't use in vain
        1992 Honda Accord EX (Coupe/Bordeaux/Auto)
        1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
        2008 Honda Accord EXL (Coupe/SanMarino/6spd)
          i first relocated the battery to the back and had current issues with my positive wire so i pulled the stock battery cables off a high mileage car. the wires and terminals were covered in battery acid.
          nothing was loose, i couldnt pull anything off until i actually yanked the wires from the terminal and it stopped the fire.
          im just worried that replacing the starter and wires, it may happen again.
            yea, it was the way i mounted the starter wire. one part of the connector was literally a mm away from the body of starter. im going to put a washer under the new starter wire and heatshrink the connector all the way to the hole of connection.
              Starter wire caught fire!? You liar! Atleast it wasn't your tire..Maybe I'll be your next buyer?
                I glanced at the title of thise thread real quick and thought it said "starter WIFE caught fire" I lol'd but then read it again. Needless to say, i was disappointed.
                Originally posted by Jarrett
                  Originally posted by vietkid_2006 View Post
                  that's a funny sig.
                  x2
                  1993 Accord LX - Sold
                  93 BMW 525it - SOLD
                  92 Accord EX Sedan - SOLD
                  2000 Accord Coupe - Traded-In
                  2003 Accord V6 6spd Coupe - Sold
                  2001 Honda Civic Ex - SOLD
                  2013 Chevy Traverse LTZ - Kid hauler
                  2003 Acura Tl 3.2 - Daily Commuter
                    id say poor contact which would of course produce immediate heat.. why its always important to make sure you have good solid wire and connections are clean, which of course you know..... right?? lol fire in an engine bay = scary shit
