Top Dead Center using lasers ?
    Does anyone know if the Honda dealerships use some special machine with lasers to put the car in TDC instead of relying on the old school method?
    1992 Accord Coupe 5-Speed
    I highly doubt they would waste money on some high tech laser machine when all they have to do is simply stick a long screwdriver down the spark plug hole.
    "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
      um no
      lol i watched a dude named allen do it on a cb7 the other day and he used the screw drive trick
      i work at honda dealer btw
      R.I.P. 6-10-07
      (\__/)
      (O.o )
      My Rotor DIY
      I'm not perfect i will make mistakes if i do just point it out to me
        Probably not, it is easiest to set the flywheel to TDC and then verify the "old school" marks while you are changing the belt. That is why Honda did it the way they did.
          i cant imagine anything requiring TDC to be more "exact" than how closely you can line it up with your eyeball...
            the flywheel is about twice the size of the damper so it should be more accurate unless the flywheel is aftermarket and marked incorrectly.
              put a dial indicator on the end of a 10" ratchet extension down the spark plug hole and you can find exactly where tdc is.
              like this
              spin city
                Thanks for the info guys. I knew this guy was pulling my leg.
