A/C question
    A/C question
    well the system has frion in it
    reciever drier is new
    compresor was used but was working
    h22
    the car was sold to me and the last owner couldnt get A/C to work on the car
    my first steps
    turn switch------------------no A/C
    pressed the schrader valve---------------------r134+dye came out
    put the gauges--------------------------------system is charged
    took out the bumper--------------------------- no leaks
    jumped high pressure switch-------------------- no A/C
    took the blue and yellow wire and ground it------------------- A/C WORKS!!!!!!!!!!
    now
    with it grounded the compressor wouldnt cycle, it would stay on
    could this be a:
    defective high presure switch?
    bad ground or no ground in the connector?
    thanks
    Just do what PR CB7 said.
    blue and yellow wire where? which wire is this?
    im going to think possibly the compressor relay mounted to the driver side inner fender?=
      Sounds like a bad ground.
      But you said it wouldn't cycle? could be a bad pressure switch.
      wat?
        thats what im thinking too
        i hope its not a the switch cuz if it is imma need 2 more cans fo effing frion
          its the 2 wires that run to the high pressure switch
          they are
          blue/yellow
          blue/black
            is the wire comming from the compressor connected?
            93 Accord LX Sedan (sold)
              yeap
              when i put ground in the blue/black wire
              clutch kicks on
              also it stays one whether i have the a/c controls on or off
              im guessing a/c realy
