Intake problem
    Intake problem
    Recently i jus bought a CAI n installed it fine, did everything as needed! I plugged all vacuum lines how needed to be done. neways when i was done i noticed that my rpm would go up n down, n when i would be at a complete stop my car would jerk and the rpm would rise. My car is a automatic, n for some reason my ac fan constantly turns on while driving. Car rpms really drops n raises too at times! so i decided n made the CAI into a short ram, but no difference! Anyone know wut could be the problem> i need help really bad, cuz im goin to wildwood in a few days! thanx!
    ILL MENACE
    Did you try to reset the ECU? The computer may be having trouble compensating for the increased air flow.
    -Jay
      nah, i havent tryed resetting the ecu. could u tell how i would reset it, thanx!
      ILL MENACE
        im sure you removed the battery while you were cutting hte hole for the CAI... so it should have already been reset...
          yea, thats tru
          plus i jus went outside and resetted it again! dont kno wuts wrong. Even as soon as i turn on the car, rpm flys up.
          ILL MENACE
            make sure that electrical tape is tight lol no idk
            u know that black box that was on the inside of the fender that i said was part of the intake? try pluggin that back in (just the plug, not the vacuum lines)... also check thru everything and make sure u didnt unplug any other things accidentally.
            also you know that thin vaccuum line that went across the back of the intake manifold (plastic line) that hooked up to the top of the intake pipe? did you hook that back up to the CAI?
              hmm, plastic line? well i plugged in the main line, n dats basically the only thing dat i see dat can go into the intake! let me go check it out, but i dont see nething.
              its dat damn electrical tape i tell you! lol!
              ILL MENACE
                well, jus went out and tried messing wit it , but nothin!
                even sprayed engine starter(contains ether) as i was told to see for gasket leaks in the intake manifold, but i found nothin! im clueless!
                my aim s/n is blaze654 if neone wants to IM me and help me out! thanx!
                ILL MENACE
                  this happened to me too, i fixed it by adjusting the screw on the intake manifold to the left (close) i adjusted it like 1-1.5 turns, if the car seems like its gonna die then turn it to the right a lil more. also reset your ecu again, this time doing it the right way.
                  pull out backup radio & ecu fuse (7.5 & 10A) for about 10 min
                  put back fuses then start the car and let it idle for 10-15 min (DO NOT STEP ON THE GAS OR HAVE THE RADIO ON, DO NOT DO ANYTHING, DONT EVEN TURN ON THE LIGHTS OR STEP ON THE GAS)
                  turn off car
                  turn on car
                  then drive normal for the 1st 20 miles.
                  helped me, i had the same exact problem.
                    if so adjust ur idle..
                    or mess with ur fast idle valve.
                    Retro!
                    Hater
                      ok, ill make sure to do that right now!
                      Ill let u kno how it goes!
                      thanx alot!
                      ILL MENACE
                        im adjusting the idle, the more i adjust it, the more air the intake takes.
                        I dunno if dats suppose to be normal. ill keep adjusting n see how it goes
                        ILL MENACE
                          anyone have a picture of where the fast idle valve is, i dunno if m doin it right, or where to adjust the intake manifold. woulld really appreciate it.
                          thanx again
                          ILL MENACE
                            for the idle screw..
                            left= more air
                            right=less air..
                            if ur idle is surging u will more than likely have to turn it to the right.. until u feel the intake sound change.. like its getting low amounts of air.. then once u do that.. turn back half a turn.. go look at the idle to see if its where u want it..
                            Praise The Lowered...
                              tryed adjusting idle, still runs like crap! dont kno nemore!:
                              ILL MENACE
