fastest engine swap
    fastest engine swap
    well guys my motor's if fucked up
    the donor motor is still in the car sine i only need the motor
    whats the fastes way to take it out or even to put it in
    #1 jack up motor and tranny
    #2 DROP motor and tranny
    #3 jack up motor only
    #4 drop motor only
    since ive done swaps all ive done is MOTOR+TRANNY SWAP al together
    so i would like ur opinion
    Just do what PR CB7 said.
    Wouldnt it be faster to pull out the motor and tranny? Because then you dont have to unbolt the tranny or anything and you dont have to put the tranny back on while still in the car.. thats what I would do..
    My s13 Ride Thread>>><<<My Rx7 Ride Thread "What is power without control?"
    New people click here
      No. You have to take the axles out for than and thats a whole bitch ( LCA Balljoints are PITA)
      wat?
        thats what i dont want
        to take out the axles and lower balljoints to swap just the engine alone
          I do believe you will have to pull the axles loose, because you aren't going to be able to get the input shaft from the tranny clear (if it's a manual).
          I don't think you would gain any time by trying to just pull the motor. Easiest way IMO is to pull the tranny and the motor together, and then separate them once they are out of the car. If you have an engine leveler, it's no big deal to swing them around.
          Good luck!
          1992 Prelude S w/swapped H22A
            You are going to have to take those axles out. I can swap axles in 30 minutes with hand tools.
            Gary A.K.A. Carter
            [sig killed by photobucket]
              Pop the lower ball joints loose and that will give you enough play in the knuckle to pull the axles out of the tranny. It's easy.
                i swapped a motor without touching the transmission or suspension.
                you can only manage this on an automatic because it has no intermediate shaft, also you can remove the flexplate off the engine which leaves room to pull it straight up. otherwise the input shaft and clutch setup get in the way.
                its not even worth it, with everything crammed in there, i only did it just to try it. it takes longer even.
                just pull the motor & tranny, swap everything around, and drop it back in.
                  what size is are the axlenuts
                  its the only thing i need
                    36mm.
                      yea just pulling the motor would be harder than pulling motor+transmission. unless you have a lift, you need to pull it out from the top.
                      spin city
                        my opinion...
                        If the you have a manual tranny .. then pull motor and tranny.. my record is 30 min in pulling it out. Change over of parts takes the longest.
                        If you have a auto tranny .. than just pull motor !!! just as fast .. i hate the torque converter bolts.. that takes the longest though. to fucking many of them for me !!
                        No matter what it should only take a whole day to do the motor swap. Two out and one in plus parts change over. It should take about 8-10 hrs depending on experience and your tools.
                        Originally posted by Devergote
                        A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
                          36MM thats what size they are!
                          92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
                          MR Thread:
                            Originally posted by foamypirate
                            36mm.
                            yup!
                            MR Thread:
                              listen to Tn_Accords pulled 2 motors, parts swap over from one to the other, installed and running, prep work on my H, parts swap over, reinstalled in about 12 hours between me and him on both those oh and this was working slow as fuck cause it was cold and shit
