VIN number confusing after Transmission Swap?!
    i was told that if i swap my transmission, it wouldn't match up with my VIN number, that is starting to worry me
    what problems could i have down the road?
    have you guys run into any problems relating to this?
    MY CB7
    FULL part out thread:
    http://www.cb7tuner.com/vbb/showthread.php?t=204494
    i think the only place that would matter is CA. i never even had my car inspected in the 8 years ive had it. CT kinda slacks off i think
      As long as you document it correctly, keep the W/O from the transmission you bought, with the VIN number, than it should be fine. As long as the transmission buy is legit, they shouldn't bother you. Assuming its the same transmission, you're not switching, if you do that, then all bets are off.
      Proud owner of the only JJDM full 2.5" catback exhaust!
        what do you mean same transmission
        like the same transmission that was meant for my engine?
        MY CB7
          i think he ment if its the same as it was b4 as in auto or manual
          PSN ID's:Tidashoni
          1992 Accord EX Coupe
          My FS Thread
          Not so DD 2013 Subaru Impreza WRX STI
          Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
            if the tranny is jdm it doesnt have a vin number so your fine. however keep you receipts as CA i heard is strict...
            if the tranny is usdm starting from 96+ (as those have vin # at the bottom side) then you need a receipt and everything from motor vehicles to claim you bought it legit.
              supposably CA is strict but they never check on it, personally i dont think they care enough for the hassle. never heard anything of having an "illegal" tranny over here yet.
              Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
              -(B-Pillar Bar Originator)-
                i read an article about cops busting street racers and the cops asked the guy for the reciept for his transmission
                MY CB7
                  so. cal got it bad lol
                    damn, CA does got it bad, Kansas doesnt even smog test....lol.
                    -RIP Eric Hall. Miss you brother-
                    newskoolhippy (10:53:37 PM): i want to see a pic of you with a hard-on to prove thats your cock
                    newskoolhippy (10:53:56 PM): i need to see your face in the pic
                    newskoolhippy (10:54:07 PM): with todays paper in the picture to prove your taking it now
                      the only time you need to worry about it is if they need to research your car to see if its stolen / has stolen parts.
                      ive installed transmissions and cut the tags off... technically illegal, but will never matter.
                        what tags?
                        MY CB7
                          the VIN tag on the transmission
                            i say, if they ever for some reason think ur engine is stolen then they'll check but if not, no problem.
                              so when im buying a used manual transmission, i should make sure the VIN tag is there
                              MY CB7
