okay so h22a is in, but starts up and almost immediately revs to 3k rpms. at which point the cel comes on. okay i said, i turn off the car and try again. this time i lift up on the gas pedal. turn on the engine on and it revs according to how hard i lift UPWARD, not downard, on the gas pedal. now in drive, i can't floor the car it only lets me go to 30 mph when i have the pedal all the way to the ground, but if i lightly put my foot on the gas it'll let me go over 40 mph and if i let go of gas pedal the rpms keep rising and i keep speeding up slowly... i check the code and it is a code 7 for something about the TPS or something. someone able to help me out on this?
Please help, idling WAY TOO high..
here a link that might help ...........if u havent found it already
http://www.cb7tuner.com/vbb/showthread.php?t=16374Last edited by shadetreecustom; 05-20-2007, 11:19 AM.F22A1:blew up
F22A1/H22:blew up
F22A6/H22: " "
F22A4/H22: " "
H23A1 boosted:blew up
H23A1:traded
H23A1/H22 built:still in progress (getting my feet wet)
drive it like you stole it
FCB7(FRANKENSTEIN CB7 CLUB)
well i unplugged the tps and now it revs to like 6k rpms... and i unscrewed the tps and it doesnt seem like it wants to adjust, before it was 3krpms now it is 6k rpms... how much do you think a shop would charge to adjust my tps?
oh and i didnt screw the tps all the way back in when i was adjusting. i was hoping that i could just move the tps around and see how it idles but that didnt work at all...
did you even READ the link on how to adjust/recalibrate the TPS sensor properly. it sure doesnt sound like it.
its so simple as long as you read the directions and have a multimeter......not hard at all.F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
it sounds like your throttle cable is holding the throttle open a little bit, indicated by the fact that idle drops if you pull UP on the pedal. let me guess, you have an LX?
when you open the throttle by hand and let it snap shut, you should hear the plate actually *snap* closed... if its a dull thunk, it may be getting caught on the throttle cable being too short... when closed, there should be a little bit of deflection/play in the end of the cable
Originally posted by 19accord92cel is cleared, but still idles badly. sometimes revs up and down and sometimes stays at 3krpm.
also, any vacuum lines that are connected to the wrong place or may be cracked/ leaking can cause the same thing without necessarily throwing a code ... especially around the intake
I'm assuming you've tried the other suggestions, which I would definitely check first -Last edited by i'm the girl; 05-21-2007, 10:47 PM.
breathing is deadly underwater...
i still say your throttle cable is holding the TB open, its the only thing thatll make pulling UP on the pedal make any difference...
i agree with you mike
PSN ID's:Tidashoni
1992 Accord EX Coupe
My FS Thread
Originally posted by deevergoteBoosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
