Anyone know how to get this thing off?? The screw is out, cap is off and the thing is parallel to the valve cover, a screwdriver won't pry it off either......????
F22b dohc dist rotor
Originally posted by vmchurchThe screw is out
PSN ID's:Tidashoni
1992 Accord EX Coupe
My FS Thread
Originally posted by deevergoteBoosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
use the thin red tube thing and drip a tiny bit of pb blaster in the screw hole, where the metal piece in the rotor meets the shaft. jiggle and pry and pull and eventually itll pull off. it gets STUCK...
Originally posted by 4CYLPOWER92If this is the same dizzy as the F22A, then all you gotta do is pull real hard. It is a bitch though, if I remember correctly.
PSN ID's:Tidashoni
My FS Thread
Originally posted by d112crzyi cant even get the screw off on mine.
or you can always just cut a slot in it...H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
