F22b dohc dist rotor
    Anyone know how to get this thing off?? The screw is out, cap is off and the thing is parallel to the valve cover, a screwdriver won't pry it off either......????
    Originally posted by vmchurch
    The screw is out
    by that do you mean the screw is out of the round part on the rotor?
    PSN ID's:Tidashoni
    1992 Accord EX Coupe
    My FS Thread
    Not so DD 2013 Subaru Impreza WRX STI
    Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
      If this is the same dizzy as the F22A, then all you gotta do is pull real hard. It is a bitch though, if I remember correctly.
      My swap thread
      Main relay proplems?--DIY
        use the thin red tube thing and drip a tiny bit of pb blaster in the screw hole, where the metal piece in the rotor meets the shaft. jiggle and pry and pull and eventually itll pull off. it gets STUCK...
          no its not same a f22ax angine it has a screw in round part of rotor mine wasnt hard at all to get off once i removed the screw but that was just my engine
          PSN ID's:Tidashoni
          My FS Thread
            I think I remember breaking mine off with a hammer. Then I removed the screw because it was much easier to remove. Then replace it with a F22A's rotor. Therefore no more screw. Well, I am not sure if the H23/H22's have a screw holding them down. The F22's fits the same.
              i cant even get the screw off on mine.
                If you have not rounded the philips screw, then get the largest philips screwdriver that fits and use it after some PBblaster or WD40. If that still don't work, (probably remove distributor from car and put in vise) I'd look into rotating distributor/engine until screw is up at 12 oclock and using a impact driver/hammer combo on it to jar the screw loose (if you have not rounded it off). If you have rounded it off, there is a special tool designed to remove rounded off screws, it digs itself into it as you turn it. I've purchased these special tools over time because it's more of a common thing in Michigan dealing with rust.
                  yea, its rounded off, lol. can i get a pic of the tool?
                    or you can always just cut a slot in it...
                      maybe if cory hadnt broken my dremel i have no more dremel.
                        lol, Joser I have one...they're pretty cheap.
                        1992 Accord LX - SOLD
                          damn russ, you have everything. thank god i know you. lol
