vtec wiring possible issue
    im having either a brain fart or a vtec issue here, im doing all my wiring now and the next step is putting in her in (tomorro if i resolve these confusions) but n e way tonight i was running my vtec wires and i came across this hole #2 with the question mark, im pretty positive that #4 goes where #2 currently is and idk what the hole is and if something goes there (im guessing it would) ---numbers 1,2 and 3 are connected as they where on the h22 harnes,(i cut the wires out of the harness and thats the lengths they came) im thnking that mayeb # 2 is an un-nessesary wire that the f22 harness already had (like #4 the head somethin, or the thermostat)
    but idk HOPEFULLY y'all arent confused too much by this and can give me some input on what the hole is and if # 2 is an extra wire i dont need cuz it was with the other 2 vtec wires
    [IMG][/IMG]
    who needs a manual anyway
    JDM is the way to play, all day every day
    cpmike would know this. He's a god.
      youre right, connector 4 is supposed to go to where 2 is connected. 1 is right, since thats a unique style of plug and thats the only place it can go, thats the vtec solenoid. that will leave you with an extra green connector #2, which is supposed to go to the vtec oil pressure sensor, which you dont have. its a 2 pin sensor that should be threaded into that empty hole. try looking in a junkyard, some vtec hondas had the pressure sensor, some didnt... if you find one that did, grab it, it will probably fit. or you could go to the dealer.
        as mike stated that missing hole is where your vtec oil pressure sensor should be. the green plug is for that sensor. #3 is a coolant line, or it looks to be pointing to it. there is a temp sensor on the thermostat housing that should be connected too so don't forget that. maybe that's what your #3 is pointing to?
        1cor10:31
        - 92 LX coupe
        - 96 EX wagon (sold)
          #3 is going to a space ship looking thing that has a hose going across the fuel rail elec connectors, its a 3 pin connector it says 11c on it and idk waht it is, lol.
          ** that shit pisses me off that im missin the pressure sensor guess i'll run to the junkyard tomorro.
          i can still start it without that right?? i'll just geta code cuz my knock isnt connected yet either && come to think of it i'm still in the dark about the external to internal dizzy wiring .. so i guess i wont be starting her
            plug up the hole with a short bolt before you start it.
            as far as external to internal wiring, plug in the new internal distributor like normal, and stick a 30amp fuse into the square connector that originally went to the ignition coil. thats it.
              k i'll plug the whole,
              now with the dizzy, theres an extra plug (3 wires) after i plug in the other two dizzy connectors, do i open up the dizzy cover and put the plug into the coil in there after putting a fuse in the connector? orr ** do i not have to open it and all i do is put a fuse in the extra connector and just leave it? this sux im mad confused
                ima tart
                why does this have to be done? what if i dont put the fuse in there it wont start? *i cut the connectors off thats partly why im so confused cuz b4 i decided to do the swap i took my head off (just cuz the motor was crap anyway and hada trannny hole the siza texas) and i took out hte dizzy to get it outta my way and THAT damn connector was stuck so i cut it on the wrong side so idk which wires to splice to the fuse
