I'm about to do my JDM H22 swap and It already has a euro r manifold and a Nissan throttle body that 95mm in diameter (http://www.cb7tuner.com/vbb/showthread.php?t=46512 ). I was wondering if and how I can still run cruise control. I understand there are sacrifices for performance but I use it a lot and it would be sweet if I still could. I have a 93 accord ex coupe by the way. Let me know what you guys think.
Can I still have cruise control with a Euro R intake Mani and Nissan Throttle Body?
Former Ride:
93 Accord Coupe
Jdm H22 w/ LSD
Type S pistons and cams
New Ride:
Bone stock 99 2.3CL
Black on Black Leather
5spd
"Experience: that most brutal of teachers. But you learn, my God do you learn."
C. S. LewisTags: None
It might be possible but it will take more time than its worth. Not sure how the Nissan cruise control works but if its similar you might be able to get it to work. If not then you might as well take out the cruise control.
I'm pretty sure that it just hooks up to the throttle rotor somehow. I also know that the f22 intake mani has two vacuum lines that go to the cruis control. I'm thinking as long as the euro r mani has those two holes for vacuum, I can rig something up with the throttle rotor.Former Ride:
93 Accord Coupe
Jdm H22 w/ LSD
New Ride:
Bone stock 99 2.3CL
5spd
C. S. Lewis
Originally posted by exratedaccord93I'm pretty sure that it just hooks up to the throttle rotor somehow. I also know that the f22 intake mani has two vacuum lines that go to the cruis control. I'm thinking as long as the euro r mani has those two holes for vacuum, I can rig something up with the throttle rotor.
all it needs is vacuum. if it came down to it, you can get a threaded hose barb and drill and tap a hole to add your own vacuum nipple on the manifold to hook it up to.
Originally posted by xScottYup, the cruise is vacuum controled, it actuates the gas pedal itself. As for this Nissan throttle body, i wanna see pics...
thanks for the imput guys. I'm just trying to work out the kinks for this swap now so I don't get into it and get stressed out.Former Ride:
93 Accord Coupe
Jdm H22 w/ LSD
New Ride:
Bone stock 99 2.3CL
5spd
C. S. Lewis
Originally posted by exratedaccord93There's a link on my first post with pics on it.
holy wow! there really is a +3" throttle body opening? but to answer this thread's question AGAIN, yes you can still run cruise as it's attached to the pedal itself and not the throttle rotor.
look at the cruise actuator (bottom right corner of engine bay) and you can see that the cable attached goes into the firewall to the gas pedal. when you're on cruise control and you use the "accel" button you can see/feel the pedal sink as if you were stepping on it.
euro-r vacuum systems are indeed fun scott .
