okay I had a minor vacuum leak checked that sealed it off with some jbweld with the brake booster nipple valve got that done. I also noticed the ground wire was comin look from the transmission got that done. Now im having a little bit of issues first off im a little bit concerned about the obd2 stuff. Now first off here are some of my concerns
1 in an obd1 h22
OBDI 93-95 H22a
Layout
A1->A25--B1->B15--Blank--D1->D21
A2->A26--B2->B16--Blank--D2->D22
Pin---Color---------Desc.
A1----brn-----------Injector #1
A2----yel-----------Injector #4
A3----red1---------Injector #2
A4----grn/yel------VTEC Solenoid Valve
A5----blu-----------Injector #3
A6----or/wht-------HO2S heater coil
A7----grn/blk1-----PGM-FI Main Relay coil
A8----grn/blk2-----Shorted to A7
A9----blk/blu-------IAC Valve
A10
A11----red2--------EGR Control Solenoid
A12----blu/red-----Condenser Fan Relay
A13----blu/wht-----MIL
A14
A15----red/blu-----A/C Clutch Relay
A16----wht/grn-----Alternator
A17----pink---------IAB Solenoid Valve
A18----orn/red-----FAS (A/T)
A19----wht----------Intake Control Solenoid Valve
A20----red/grn-----EVAP Purge Control Solenoid
A21----yel/grn1----ICM
A22----yel/grn2----Shorted to A21
A23----blk1---------GND
A24----blk2---------GND
A25----yel/blk------PGM-FI Main Relay (power)
A26----blk/red------VTEC Pressure Switch (GND)
B1----yel/blk--------PGM-FI Main Relay (power)
B2----brn/blk-------GND
B3----orn1----------AFSA (A/T)
B4----pnk-----------AFSB (A/T)
B5----blu/blk--------To A/C Switch
B6
B7----lt grn---------ATP PN Gear Posisiton (A/T)
B8----red/grn-------PSP Switch
B9----blu/red-------Starter Cut Relay
B10---orn2----------VSS
B11---orn3----------CYP
B12---wht-----------CYP
B13---orn/blu-------TDC
B14---wht/blu-------TDC
B15---blu/grn-------CKP
B16--blu/yel--------CKP
D1----wht/yel-------Battery
D2----grn/wht1-----Brake Switch
D3----red/blu-------KS
D4----brn/wht------SCS
D5
D6----lt blu or lt grn-VTEC Pressure Switch
D7----lt grn/red----Data Link Connector
D8
D9----wht/red------ALT
D10---grn/blk------ELD
D11--red/blk-------TP Sensor
D12---wht/blk------EGR Valve Lift Sensor
D13---yel/blu-------ECT Sensor
D14---wht----------HO2S Sense
D15---red/yel------IAT Sensor
D16
D17---wht/blu------MAP Sensor
D18---lt grn/blk----VREF (A/T)
D19---red/wht------EGR Valve Lift Sensor
D20---yel/wht------TP Sensor
D21---blu/wht------MAP Sensor
D22---grn/wht2----TP Sensor
now heres obd2
OBDII H22a 96+
Layout
A1->A11----Blank--C1->C10---D1->D5
A12->A24--Blank--C11->C22--D6->D12
A25->A32--Blank--C23->C31--D13->D16
Pin---Color ---------Desc.
A1----yel------------Injector #4
A2----blu------------Injector #3
A3----red------------Injector #2
A4----brn------------Injector #1
A5----orn/blu-------Secondary O2 heater
A6----blk/wht-------HO2S heater
A7----orn------------EGR Control Solenoid Valve
A8----grn/yel-------VTEC Solenoid Valve
A9----brn/blk-------GND (dig)
A10---blk------------GND (power)
A11---yel/blk-------PGM-FI Power
A12---blk/blu-------Idle Air Control Valve
A13
A14
A15---red/yel-------Evap Purge Control Solenoid Valve
A16---grn/orn-------Fuel Pump Relay
A17---pnk/blu-------A/C Clutch Relay
A18---gry/red-------MIL
A19---wht/grn-------ALT
A20---yel/grn--------ICM
A21
A22---brn/blk--------GND (dig)
A23---blk------------GND (power)
A24---yel/blk--------PGM-FI Power
A25---wht-----------Intake Control Solenoid Valve
A26---red/blu-------IAB Control Solenoid Valve
A27---grn-----------Radiator Fan Relay
A28---grn/wht------EVAP Bypass Solenoid Valve
A29---orn/grn------Evap control cansiter vent shut valve
A30
A31-
A32-
C1---lt grn/blk------Ref. Voltage for ATTS or TCM (not used)
C2---blu------------CKP Detect
C3---grn------------TDCP Detect
C4---yel------------CKP Detect
C5---blu/orn-------A/C Switch Signal Input
C6---blu/red-------Starter Switch Input
C7---red/wht-------SCS
C8---lt grn ---------K Line (scan tool)
C9-- -
C10---wht/yel------ECM Backup Power
C11-- -
C12---wht----------CKP GND
C13---red----------TDC M Side
C14---blk----------CYP M Side
C15---blu/blk------VTEC Pressure Switch
C16---grn----------P/S Pressure Switch
C17---wht/grn-----ALT Detect signal
C18---blu/wht------VSS Signal
C19 -
C20 - -
C21 - -
C22---brn/yel------IMO Immobilizer Code Signal
C23- -
C24 - -
C25 - -
C26 - -
C27 - -
C28 - -
C29 - -
C30 - -
C31 - -
D1----red/blk----------TPS Detect
D2----red/wht---------ECT Engine Coolant Temp. Detect
D3----red/grn---------MAP Detect
D4----yel/red----------Vcc1 (Power for MAP)
D5----wht/blk----------BKSW Brake Switch Detect
D6----red/blu----------KS (Knock Sensor Detect)
D7----wht--------------HO2S Detect
D8----red/yel----------IAT Intake Air Temp Detect
D9----wht/blk----------EGR Valve Lift Sensor
D10---yel/blu----------Vcc2 (Provides Sensor Voltage)
D11---grn/blk----------SG2 (Sensor Ground)
D12---grn/wht---------SG1 (Sensor Ground)
D13- -
D14---wht/red---------SHO2S (Secondary O2 Sensor Detect)
D15---wht/blu---------PTANK (Detects fuel tank pressure signal)
D16---grn/red---------EL (Detects ELD Signal)
now heres the kicker the pinout for section a slot four is different for the obd1 and obd2 for the vtec solinoid. It says vtec for obd1 and for obd2 its for the injecotor 1 and the solinoid valve is on a8 instead of a4
now the second issue i have is for the iab's a17 for the obd1 and on obd2 its for the clutch relay hmmm and i get a egr valve code im not sure if i wired it wrong or if its the obd2 switch up in the pinouts an help from someone whos's obd2 i also have a slight misfire at idle after i run it hard i dont have a catylic converter and im runnin the same injectors that came with the motor. do i need to get the 345cc's basemodel injectors? oh and btw my vtec still activates too
1 in an obd1 h22
OBDI 93-95 H22a
Layout
A10
A14
B6
D5
D8
D16
now heres obd2
OBDII H22a 96+
Layout
A13
A14
A21
A30
A31-
A32-
C9-- -
C11-- -
C19 -
C20 - -
C21 - -
C23- -
C24 - -
C25 - -
C26 - -
C27 - -
C28 - -
C29 - -
C30 - -
C31 - -
D13- -
