h22a1 usdm swap problem
    i just recently swapped a 94 usdm h22a1 and trans with the lude's cv joints it makes a rumbling sound go down the road at 15mph the car is dropped and i heard there's a problem lowering the accord with h22a1 swap and if u do swap u have 2 use the lude's knuckle or something can someone please help
    H23vtec
    Kee Built/Tuned
    87x95 11.7 compression, custom h22 intake, minor head port polished, 70mm tb, 3inch cold air/3inch vstack, stock cams,ebay header with 3inch collector,3inch exhaust.
    9.0's at 81mph in the 1/8th mile ohh how i miss my baby.
    yea but i was told the axles would work but they are a bit longer also i couldn't get the axle 2 fit
    H23vtec
    Kee Built/Tuned
      im going to assume you couldnt get the axle 2 fit because it is a bit longer.
      use all your stock accord axles.
        sorry
        i didn't finish i last statement
        no they fit perfect the only problem is u have 2 get a couple of big washers the size of the axle nut about 4or 5 on both sides b/c the the longer cv joints that may be the problem b/c i haven't installed washers yet i just tightened them up all the way just 2 see what was going 2 happen really i just wanted 2 know has anyone physically attempted 2 install the prelude cv joints on there accord that's all is it possible i know that the accord will fit but they are alot weaker and break really easily on good launches but if it can't be done i'll reinstall the accord axles and just upgrade later on but that's really the big problem i wan't be able 2 put washers on the end of the cv joints today b/c it's raining in NC today and tomorrow suppose 2 any way just wanted some good info i have searched all i could and i ran across a couple people who have used the lude's axles and some who have upgraded
        please don't flame just wanted some good info
        H23vtec
        Kee Built/Tuned
          the way i have my axles set up, i have the full accord passenger side axle, and for the driver side i have the prelude intermediate shaft, and an accord axle with a prelude inner CV joint to match up to the intermediate shaft.
          strength benefit? not worth the work of swapping the joint and bearings. use all accord axles. i only did it because of a time constraint and i couldnt find an accord intermediate shaft and had prelude axles handy.
            us accord axles
              ok i put the accord axles and intermediate shaft back in and the wobble is gone. thanks for the input just gonna have 2 save up and upgrade axles later on.
              yeah h22 swap done
              H23vtec
              Kee Built/Tuned
                yeah h22 swap done
                dah.. i wouldnt worry about it too much.. ive been boostin the shit out of my turbo h22 probably putting down close to 300whp.. and one of my cv joints even has a tear in the boot ... but they havent shit the bed yet... the stock cvshafts are stronger then you think...
                  oh ok
                  kool
                  H23vtec
                  Kee Built/Tuned
