who has retained the reverse back up light after an h22 swap? i cant seem to figure out which wire on the tranny is the reverse light.
Reverse Backup Light
swapping manual tranny for manual tranny, they should be identical. its the two wires sticking up from the center of the tranny, the green and yellow ones. they dont use a regular plug, they are both round quick disconnect connectors. only time you need to worry about hooking up reverse lights is when you swap auto to manual?
just what mike said. the reverse lights have two plugs, one is green and one is grn/yel (if i remeber correctly. There will be a soiliniod lookilike thingy near where the shifter cabeles mount up but...closer to the engine.
It's pretty straight forward. good luck2DAO (2 Door Accord Owner)
JDM H22 DOHC 200/161 2.2L
My members ride: http://www.cb7tuner.com/vbb/showthread.php?t=20385
you can buy some plugs and re-wire them...i had a similar experience, i fubared my plugs but i fixed it really fast.2DAO (2 Door Accord Owner)
Originally posted by tommianyone have pictures ?? from auto to manual, what you did and process i need to know this soon.
Since I have no pic, here is a ghetto drawing of how the pins in the terminla are laid out. There are two rows, each letter is a wire, the dash next two the F is an empty pin, the two bold I are places where plastic connector parts go in, and teh little clip thing on the outside is under the second row
A B I I C D E
- F G H I J K
The reverse lights are in G and H.
Hope this helps.
"Cars to me are meant, above all else, to be driven no matter what is done to them..."
- RJ de Vera
If you are still having problems check this...
http://www.accordinglydone.com/forum...mission+wiring
- RJ de Vera
hmmmmm.... well if you go to www.accordinglydone.com under "technical garage" in "tech articles" and search for "Automatic to Manual Transmission Conversion" the thread should come up...
- RJ de Vera
