Ok I have a f22b single cam non v tech. And I'm trying to put my tranny on from a 93 accord. Evrything bolts up perfectly but where you tranny goes on in the middle it goes thru the middle of your pressure plate it that's. Where my problem is. It won't go thru there at all. And i used my clutch allignment tool so its alligned correctly but it still does not want to go on all the way. What can I do to fix this problem or for it to go thru the middle of the pressure plate?
tranny does not want to go on motor!!!!
obviously you did your best aligning the clutch plate, but double check it again. you greased the inner splines, right? make sure you are pushing the tranny on STRAIGHT and not letting it sag. ALSO: make sure the alignment dowel pins are not interfering. there are 2 hollow pins on the edge of the housing (one on either side) that line up between the housing and block, sometimes people leave an extra peg in there ("came with the tranny") and they obviously cant both occupy the same hole, so the tranny never sits flush.
my recommendation if all else fails: get somebody to put a wrench on the crank pulley on the other side and wiggle it back and forth a little, while you are pushing the tranny on. usually helps.
Originally posted by flashbycb7 View PostOh and also you explained it well but I don't understand what you were talkin about 2 dowels? What are they? And yea I was going to do the little crank puller trick but I'm doing my swap by myself lol
they look like this:
but sticking out of your transmission instead. later.Last edited by TypeG; 07-18-2011, 10:10 PM.
Originally posted by flashbycb7 View PostI got the tranny on and everything sits flush but the bolts don't want to go all the way in like there too. Long there tightened all the way but still have about a inch left to go in...
Slightly OT but would still apply, another good lesson would be to make sure that the clutch disk actually slides directly onto the tranny's input shaft before you install the clutch. I had an action clutch where the splines on the disk were mis-machined and it would not even start to slide onto the shaft.
