how to conect reverse light after 5 speed swap?
    hi , i searched alot on here for my 5 speed swap and this site really helps me.but i`m confuse.i dont want to put new wires from the reverse switch on the tranny to the grey conector on the auto shift selector.i heard a method where you can pass trough wires that goes to the TCM.you conect the yellow(from center console) to the red/white wire that conect to the TCM and the green/black wire(from center console) to black/white wire that conect to the TCM.the interior part is ok, but wich wire do i conect to the reverse switch under the hood?or i missed all? sorry for my english , i speak french usually.
    ps : i love cb7tuner.com
    http://www.cb7tuner.com/vbb/showthre...085#post703946
    MRT
    sneaky motherfucker
      i guess you didnt read the entire post.i want to pass trough the wire from the TCU...
        i found the way to go!
        you just have to cut the conector off the wires that conect to the old automatic transmission.i took the one with the orange/blue and blue/white wires.the other end of the wires is on the conector that was going to the TCM(same color).just to be safe when you doo it , take a multimeter and chek for continuity on the wires.you just have to extend the wire from the TCM to the center console and thats it.
        hope that help someone!
            better way IMO
            93 Accord LX Sedan (sold)
