Q: Will this fit?
    Q: Will this fit?
    Will 17x7, 4x100 with a 42 offset fit our cb7's? or will a 4x114.3 fit?
    My 1993 LX
    Our cars are 4x114....those won't work.
    1992 Accord LX - SOLD
      You could get some wheel spacer adapters....however those are dangerous and really only good for putting fwd offset rims on rwd cars.
      If you do manage to source some 4x114.3--->4x100 They are really rare from what I seen since the most common spacers found on e-bay do the opposite.
      I saw a jdm set (probably quality i would trust) that convert 4x114.3 to 4x100. The set was taken off a silvia. It's really uncommon I think since most adapter kits being sold are the other way around. At one point I wanted to put some jdm civic modulo rims that look like the oem euro-r's just in 16's...but never came across an adapter. I bought some subzero copies and then I happened to see that adapter on e-bay. (2years back)
      The dangerous things about them is that, the new extended wheel studs may be cheaply made and snap if they are too generic.
      It's mainly for show really. I wouldn't consider it for daily driving use. It's the opposite if you are running say OEM 4-lug type-R's on a cb7 where u would need the spacers for clearance. These spacers just space out the hub...not add new cheap wheel studs.
      If you like to race or run hard, I've heard your wheel bearings may also go out on you much quicker than normal.
      This is an example of what the various conversion spacers look like.
      I need a custom turbo manifold built....
      707 NorCal NinjaZ
      Honda Twincam Motorwerkz?
      "I am the Yakuza CB7!"
      '92 Accord Sedan SiR
        4x114.3 will fit not the 4x110
        本田**AcCoRd**本田
        Click to see my CB7
        '90 CRX SIR - Imported from Japan --- Daily Driver
        '93 civic hatch -sold
        '98 Civic H22 Turbo -sold
        '92 Accord ExR coupe- sold
        '96 Golf- Sold
        '96 Bmw 328-Sold
        '01 Civic Si-Sold
        '99 Maxima-Sold
        '88 Crx-Sold
        '91 Accord H22-sold
        '97 Civic Coupe-Sold
        '95 Civic HB b16b-Sold
        '93 Accord-Sold
        '89 Prelude Si-Sold
        '91 Crx Si-Sold
        '93 Honda accord-Sold
        '88 Ford Exp-Rip
        '92 Tracker-Sold
        and many more lol(just dont want to take all the place lol)
          so what should i look for when purchasing rims for my cb7?
          My 1993 LX
            17x7 +42 4x114.3
              that'll work for our cars mike?
              My 1993 LX
                nope, those are the specs for a 1983 VW Rabbit. i figured id just throw them out there while we were on the topic.
                  are you being sarcastic?
                  My 1993 LX
                    yeah i was, sorry yes those are the specs for a set of 17's that would fit the CB7's. i believe you can get away with a 40mm offset if necessary.
                      lol ...thanks man. oh by the way, love what you did with your cb. I went thru your entire members ride page to see what you did. Very Clean!!! I think you have the cleanest engine bay on here. Great job!
                      My 1993 LX
                        Yep, you can...but be prepared to rub a little on a moderate drop, and probably rub more with a bigger drop, especially if you're using a 215/45 tire. Nothing rolling the fender or running a slightly smaller tire won't fix.
                          Thats why i mentioned finding a hard to find wheel spacer that'll convert it? That picture above was only used for an example of what they would look like.
                          (note example on the bottom of the picture) yup those are 4x100 versions.
                          4x114.3 to 4x100 downgrade spacers are rare but do exist... You can find 4x100 to 4x114.3 all day on e-bay. Custom ones that do the opposite of that are rare from what i've seen. I wanted some 4x100 wheels and bought me some rims...then i saw that jdm wheel spacers off a 4-lug nissan and then was shocked they had something like that. JDM parts are nice for that fact of being rare.
                          707 NorCal NinjaZ
                            Ok found a picture of a ended e-bay auction here you go! I know e-bay links are not allowed...but I don't find this a EXTREME rare part since now by doing a good search...they are a dime a dozen?
                            http://cgi.ebay.com/ebaymotors/ws/eB...m=260042734333
                            This auction has ended and this is a "off brand" one and doesn't look quality like the one i've seen 2years back.
                            This one looks thick and beefy but I wouldn't recommend it. Try finding a used or new jdm one thats from a respected company and purchse that.
                            Hope this helps.... New Civic or jdm 4x100 wheels anybody?
                            707 NorCal NinjaZ
