ABS to NON
    ABS to NON
    well i gotta ex
    abs dont work
    dont wanna fix it
    wanna get rid of it
    is getting in ma way of wire tucking
    iknow that cp mike did his conversion
    anyone else know how to do it
    is it just buy a master cylinder non abs
    and direct the lines
    and gut everything or am i missing something
    cuz that pump and relays are really there for nothing i believe
    i already did a diag and i gotta replace the PUMP
    NOTTTTTTTTTTTTTTTTTT
    gonna do that
    if i take it of there it will be for good
    anyone can help me?
    thanks
    Just do what PR CB7 said.
    you need a non-ABS brake master cylinder
    an integra 40-40 proportioning valve
    and the engine bay brake lines from a non-ABS cb7.
    all of this is visible in the picture below.
    remove all current lines and wiring for ABS and the only two brake lines you KEEP are the two that run down and along the underside of the car... the rest are replaced with the non abs ones
    [img]http://www.****.com/pics/92exr/euror_removal/000_0346.JPG[/img]
      So what are the advantages of non-abs? Just for clarification. Also, is I thought I read somewhere that you said it wasn't worth it if nothing was wrong to begin with. Is that true?
      Originally posted by Maple50175
      Oh here we go again. Maples other half.
        its a tradeoff, a safety feature vs. the simplicity and directness of not.
        abs is proven to be an effective at reducing low traction stopping distances and help prevent wrecks.
        but god its so damn annoying and complex!
        the way i drive my car i often lock my brakes and use them beyond the threshold of "normal" braking before ABS would kick in. so the pulsating pedal and loss of direct control really bugged the shit out of me. so not only is it now better to drive, but the engine bay is SO much simpler and emptier.
        you have to consider the fact that not only does it include the huge mass of brake lines, but also the pump, distribution block, ALL the wiring and isolated fuse box, PLUS the wiring and sensors to each of the wheels, it definitely takes up a lot of space!
        so in most cases (people with stockish cars inquiring about removing ABS) it is MUCH simpler to just disable the system electronically instead of tearing EVERYthing out. also if its already working fine in the first place, the safety benefit it provides (it WAS invented for a reason) is usually worth just saving the work, and leaving it in to do its job.
        in the cases where people are rebuilding cars to their own preference and already have everything out (or easily accessible) it could be worth the swap, if its not a feature of the car that you would like to retain. especially if it doesnt even work in the first place. and definitely if you got all the parts free like i did :P
        if you dont have a specific/personal reason why you want to remove it, you may want to leave it, as it may save you/your car someday. but hey we all make compromises as we mod...
          I got a 92 EX with ABS. I don't like it, so I just unplugged the ABS computer in the trunk for now. I like it alot better. Plus, I think with my front big brake setup, I believe that I can stop better and faster! I just can't hit the brakes too hard, cuz I will lock up the front tires. LOL
          97 Yamaha YZF600R
          Vouches: wagalude/sleepycb7/accordexr33/yeamans17/heylookitsdylan/tommi/JDMH22ACB7/smokeeey420/sackingz123/
          IDriveALude/Losiracer2/626cb7
            hey mike
            how much time it took u to do the conversion????
            and as far as level in expertixe
            cuz i know how tho bleed master cyliders
            do all kind of brake work
            but never have converted a car from abs to regular
            is it a pain in the ass
            or just replace
            and bleeed?
              Just replace and bleed. Once you remove the ABS stuff, you only have to worry about installing the non-abs stuff. If you know how to work on brakes, and have the tools to do so, it's easy.
              Converting from non to ABS would be difficult... the other way around... not so much.
              You're removing a complex electronic/hydraulic system and replacing it with a fairly simple hydraulic system.
                so with the abs harnesses wats up with that
                cuz i see them like going into the main harness?
                  snip snip!
                    sounds easy i had to disconnet the abs on my car casue i did a rotor of hub conversion on my 93 lx non abs and when i bought my 92 ex just swaps knockles out and didnt know that it was that easy to remove the abs completely... :-D
                    cb7's and three titty women with two vaginas is all we need in life j/k
                    MEMBERS RIDE PAGE
                      i got three teg 40/40 valves.
                      PM me if you need one.
                        well what about if your swaping a 92" f22a6 motor to a 90 4dr ex? how will i take the ABS away? or will i not have to?
                          ABS has nothing to do with the motor.
                            ABS is a safety feature for people that arn't very good at driving. not being offensive but there is a large range of driving abliity... ABS is a computer that mimics good drivers ablilty to threashold brake allowing them to slow down and change direction at the same time.
                            - most of the general public has no clue when it comes to keeping control of a car... even worse, the only real way to learn is by throwing your car out of control in safe environments (parkinglots... which is illegal). So instead they made a computer so that everyone, even idiots could swerve out of they way of small children.
                            - I belive its been proven that ABS INCREASES stopping distance, but you retain the ablility to turn the whole time, supposedly making it safer.
                            Engines hate me... thats why they commit suicide
                              You can NEVER pump the brakes as fast as an ABS system. The ABS in my GTP has saved me a few times already. Without it, I wouldn't have been able to stop. I'm used to the lighter CB7, so I brake later than I should with that heavy car sometimes.
