How are the tie rod ends supposed be positioned thread wise. I got an alignment but Im in the process of getting a new r&p. How far on the tie rod should it be screwed since you are taking that and the nut off and putting it on the new rack so the toe wont be off.
Tie rod/toe q?
if you are changing your rack your toe is going to change regardless. but to get it as close as possible you need to count the turns when taking the tie rods off, and put them on the new rack the same amount of turns. This does not mean your alignment will be the same...you will still need to have a toe adjustment done. hope this helps and if you have any more questions, ask away."I can imagine no more rewarding a career. And any man who may be asked in this century what he did to make his life worthwhile, I think I can respond with a good deal of pride and satisfaction: 'I served in the United States Navy." --President John F. Kennedy
ASE Master Automotive Technician
ASE Master Med/Heavy Truck Technician
US Navy Electrician
Contact me if you need help on the side.
'92 Accord DX (For Sale)
'01 Civic LX
'00 Tahoe
Greatest Rally Video Ever
Originally posted by drkshdw107if you are changing your rack your toe is going to change regardless. but to get it as close as possible you need to count the turns when taking the tie rods off, and put them on the new rack the same amount of turns. This does not mean your alignment will be the same...you will still need to have a toe adjustment done. hope this helps and if you have any more questions, ask away.MR Thread- I brought SEXY back- LOL
If it jams, force it. If it breaks, it needed replacement anyway.
Never argue with an idiot, they drag you down to their level and then beat you with with experience!!!
Well i observed today that my tie rod end and the inner boot have somehow unscrewed some so the nut isnt in the same spot. it was 1/4 of the way toward the boot so i know that it is all jacked up now. And another question, I took off my steering wheel to rewire the horn so it would work. How do you re-align the steering wheel in the correct spot since now its pointed near 10 oclock while going straight? I tried backing out, driving down the street coming back into the driveway and unbolting the steering wheel and putting it back on with the wheels straight but its still off.
Originally posted by jtek24Well i observed today that my tie rod end and the inner boot have somehow unscrewed some so the nut isnt in the same spot. it was 1/4 of the way toward the boot so i know that it is all jacked up now. And another question, I took off my steering wheel to rewire the horn so it would work. How do you re-align the steering wheel in the correct spot since now its pointed near 10 oclock while going straight? I tried backing out, driving down the street coming back into the driveway and unbolting the steering wheel and putting it back on with the wheels straight but its still off.
and Mike, not everyone will straighten the wheel for you. Be sure to ask.MR Thread- I brought SEXY back- LOL
ok, i've gotten an alignment before and I have never seen they guy doing it turn the tie rod ends to get it straight. So explain to me how the "electronic alignment system works" or how they align the wheels because all I see is them hooking something to the front wheels and looking at a computer and pushing buttons. They must get under the car and turn something? So if i put the new r&p on and put the tie rods on and take it to get aligned they will make it right?
Originally posted by jtek24ok, i've gotten an alignment before and I have never seen they guy doing it turn the tie rod ends to get it straight. So explain to me how the "electronic alignment system works" or how they align the wheels because all I see is them hooking something to the front wheels and looking at a computer and pushing buttons. They must get under the car and turn something? So if i put the new r&p on and put the tie rods on and take it to get aligned they will make it right?Gary A.K.A. Carter
[sig killed by photobucket]
New Problem!!!
I am about to go get my rack and pinion this week for $55 bucks, which is a steal. But I have another major problem, I keep on breaking Lug Bolts for some strange reason. Is it because of the bad rack and pinion plus bad alignment or what? 2 broke off the front driver wheel at almost the same time and I almost wrecked since only 2 of the 4 lugs were on the wheel...no good! So I was just wondering what is the culprit?
