I just bought some prelude blades off of a 95 prelude and I put them all on and when I turn to the right it hits like crazy. but not when I turn left. WTF I thought they were direct swaps? also I can use the same stock lugs right?
prelude wheels hitting
which blades did u GEt, the ones that look like gsr blades. of the saw blades that turn to the right**Blk Housed Slut Crew Member #1**
Originally posted by Stealthman80I just bought some prelude blades off of a 95 prelude and I put them all on and when I turn to the right it hits like crazy. but not when I turn left. WTF I thought they were direct swaps? also I can use the same stock lugs right?-1992 Accord EX H22 234whp 185wtq
-1993 Accord EX SOLD
-1995 Accord EX Wagon Daily Driver
-2012 GMC Canyon V8 4x4
mine scraped too.
how are your wheel bearings? loose at all?
umm ok it was doing it when I turned to the right, then I switched the front wheels around now its doing it when I turn into the left, its going clunk, clunk, clunk, clunk when I turn, the faster I go the faster it clunks? umm the tires on them are 195/65 15 so there 5 higher but that shouldn't cause a problem? why is it only the one wheel. I was in the guys car when he came to exchange them and there was nothing wrong with them
Its these
I havent switched the wheels around..but thats the same ones I have, and they make the same described clunk ONLY when turned completely. I am running the OEM tire size (195/60/15) and did not have this sound start untilt he sawblades went on.
As far as I know my bearings are fine.-1992 Accord EX H22 234whp 185wtq
OH, is the balancing weight mounted on the inside of the rim? if it is, it rubs itself off every time it passes the knuckle...
Sounds like the wheel is bent, majorly out of balance, loose or broken wheel weight, or the wheel itself is damaged internally... When I first read this I was thinking CV axle or bad wheel bearing but if you have moved it from one side to another and it just happens where this one wheel is, then it definatly sounds like it is something with the wheel itself... Did the wheels come off of a wrecked car? Later
Originally posted by cp[mike]OH, is the balancing weight mounted on the inside of the rim? if it is, it rubs itself off every time it passes the knuckle...
-seanMembers ride 15.927 @ 86.76 (f22a1)
Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
Arcadia Green Crew #10
I found it, the wieghts are hitting the knuckels at full turn. Because I just realised the stock wheels are 5 1/2 inches wide and the prelude wheels are 6 1/2 inches wide, at full lock I can't even fit a finger between the wheel and the knuckle. Thanks for the help guys. now I need to get them rebalanced cause there fuckin bad I must have knocked a wieght off when testing it
