5 lug conversion question
    i have 97 prelude knuckles that have been waiting to be swapped onto my car. but i was just wondering if any of you guys have changed the lower ball joint instead of grinding out the lower control arm. reason i ask is because i pressed out the prelude ball joint and tried using the accord ball joint but the accord one is too small just by a little. just wondering if there was any other alternative. thanks guys
    Frost White CB7 Crew #26
    i changed my lower balljonts coz they were shot.. but i used the same balljoints that came with the lude arm..
    Click sig to view MR thread
    Links to other rides:
    Honda Accord Euro-R
    Honda Odyssey Absolute
    Honda City I-DSi
    Honda Stream
      did you use prelude lower control arms?
        lude LCAs are entirely different and are nowhere close to fitting...
        unless you can find a balljoint that fits the lude knuckle and has a 17mm nut, your only option is grinding...
          alright so i did the front 5 lug conversion over the weekend. only problem is i have positive camber on one side. and negative camber on the other. i dont understand why i would have positive camber. ive done an alignment on it already. just wondering if a camber kit would help at all. cuz i kno there supposed to help negative camber. but would they help positive??
            bump. i need to fix this positive camber
              try and get a camber kit
              if u push (pump) ur arms, theres a possibility it might damage ur bearings and stuff
              btw, how'dya get positive on one side and negative on the other? i got a lil positive camber (0.9 deg) when loaded with me only,but when unloaded, its almost neutral..
              Honda Accord Euro-R
              Honda City I-DSi
              Honda Stream
                yeah thats weird, did you mix and match upper control arms?
                  yeah i dunno its weird. i didnt use different UCAs. there both accord. i used same prelude knuckles. are lude UCAs shorter than accord ones? or same? i need somethin that'll pull the knuckle in more. i dunno its weird. i got +2.0 on the left and -1.8 on the right. i have spare lude UCAs from a 94. they have camber kits on em. ill try giving that a shot. other than that i dunno
                    http://www.mycb7.com/bb/viewtopic.php?t=2539
                      Maybe your front crossmember is shot. Or the knuckles were from a crashed car
                      Originally posted by lordoja
                        Old thread is old.
                          the lude uca is shorter then the cb so the lude knuckle naturally gives a camber difference. before trying to figure out any camber problems (either + or -) you should get a camber kit for the front and go from there.
                          click to see my ride
                          click to check out my bb6 dash swap
                            Originally posted by Jarrett View Post
                            Old thread is old.
                            yup
