I think cb7s can use both rear strut bars and xbars im not sure though. As far as the fender braces Im sure a custom set can be made by taking some micro measures and making a template for a machine/engineer shop to laser cut. I want to know more about those inner "skeletons" that EK chassis use.
subrame braces
id love to have a rear x-brace like oneoff posted. my only thing is that for me to ever install it, the X part would need to be removable, with the strut bar being permanent.
there is alot of information in this thread that seems dangerous and easily misinturpreted.
first, if you are serious about racing, the only goal for the rear end sway is a stiff enough sway bar to lift your inside tire going through turns.
if you are into hydrulics you are probably bouncing around... shear wont do shit, when you have a bending moment from the front of a car being in the air, or for that matter hitting the ground again, hence the brace right in the middle of the car where the bending moment will be the worst.
for cars the body roll is the suspension giving (its meant to) when you stiffen the car you reduce body roll.... a well known concept...BUT when the suspension/anti-roll subframe is too stiff it doesnt give, POSSIBLY a good thing, except you would find all 4 wheels on the ground in turns why? cause load travels to stiffness, meaning your suspension is now twisiting the frame enough to keep all 4 wheels on pavement (VERY BAD FOR THE CAR you are actually twisting the body in torsion )
you lift a wheel...to keep the body as straight as possible, this cant be done due to the weakness of your passenger compartment... the only way to acheive the body strength needed to stay straigh and lift a wheel is with a roll cage.
No 1 part of a race car is gonna work out like you think on your street car. all together as a package they do well.
Much of the information seems to be a mix of mechanics, and RWD race car setup... although there isn't alot of information in the US for FWD race setup there is some, and most of it only states that RWD setups dont work... and the set up/ technique for driving a FWD car varys with every modification/ driver/ Manufacture.
SO PLEASE in a quest for stiffness dont destroy your car... rear end roll in a FWD street car is favorable in comparison to a RWD RACE car.
i haven't seen any GT-Light 4th gens, so i dont think anyone here has a FWD RACE car accord, if you do... why the hell haven't you posted pics!
LASTLY... stiffness is good for racing, not gonna lie... i see RWD mustangs lifting the inside front tire on acceleration... and i see FWD civic hatches lifting the inside rear wheel on braking... but only on a race track!
honda's last cause they designed them well, meaing low stresses and high design factors. in impact loading (sudden loads) stiffness increases stress ALOT! so as you are stiffing your car you are in fact reducing its life...
Race cars dont last to 200,000 miles.....
JohnL: i am not attacking your information, as you mostlikely know the affects of stiffness, but i am trying to deliver both sides of the stiffness debate so that anyone that reads it may also know the downside to extreme rigididty.Last edited by GreenMadness; 01-15-2008, 05:11 PM.Engines hate me... thats why they commit suicide
Originally posted by slickpost pics of your setup. I wanna see what type of x brace you have so i get a good idea
My 'X' brace looks very similar to that beige coloured one that someone else posted, but instead of sitting flat in the boot space it sits more or less vertically behind the seat back. It attaches to the rear parcel shelf metal work with two bolts on each side (the same two bolts that attach the stock angled sheet metal braces on each side of the seat aperture, which are also retained in front of the X brace), and at the bottom is bolted to two 3mm thick plates (one each side) that are attached to the chassis behind the stock braces, again using the existing stock brace attachment bolts (two per side). These stock chassis bolts are not as large as I'd like, but fitting larger bolts would mean dropping the fuel tank, which isn't likely to happen!
The X brace is designed to prevent the section of chassis behind the seat back (including the area between the strut tops) from 'trapezoiding' (is that a word?!) under load, and generally stiffen the rear of the chassis where the loads are imparted into it. I also have a rear strut brace that is also bolted to the centre of the 'X' in the brace (using two short tubes). I noticed improvement in response and understeer (i.e. less understeer) with both the strut brace and the X brace, strut brace probably more so than the X brace, but it's hard to say which really has the most affect since I haven't had the X brace fitted without the strut brace. I have to say I noticed no improvement when I bolted the strut brace to the X brace.Regards from Oz,
John.
Originally posted by GreenMadnessthere is alot of information in this thread that seems dangerous and easily misinturpreted.
Originally posted by GreenMadnessfirst, if you are serious about racing, the only goal for the rear end sway is a stiff enough sway bar to lift your inside tire going through turns.
Originally posted by GreenMadnesstif you are into hydrulics you are probably bouncing around... shear wont do shit, when you have a bending moment from the front of a car being in the air, or for that matter hitting the ground again, hence the brace right in the middle of the car where the bending moment will be the worst.
Originally posted by GreenMadnessfor cars the body roll is the suspension giving (its meant to) when you stiffen the car you reduce body roll.... a well known concept...BUT when the suspension/anti-roll subframe is too stiff it doesnt give, POSSIBLY a good thing,
Many years ago before these things were really understood, it was not uncommon practice for racing engineers to hack out some part of the chassis in an attempt to improve handling balance, and it often worked to a degree, but the reason why is that the suspension rates themselves were too high either at the front or the rear relative to each other, so softening some part of the chassis addressed this deficiency in a rather clumsy manner.
Originally posted by GreenMadnessexcept you would find all 4 wheels on the ground in turns why?
I suspect you are confusing body roll with weight transfer, they are not the same thing. The less roll stiffness there is the more the body will roll, but this only changes the speed with which weight transfer occurs (slowing it), not the degree to which it will ultimately transfer (assuming lateral acceleration remains the same, though it will probably lessen if roll is too great due to camber change affects). The affect of increasing or decreasing roll stiffness at one end of the car is to alter the distribution of a given weight transfer (i.e. the roll couple), though it wont change the overall weight transfer all else being equal.
Originally posted by GreenMadnesscause load travels to stiffness, meaning your suspension is now twisiting the frame enough to keep all 4 wheels on pavement (VERY BAD FOR THE CAR you are actually twisting the body in torsion )
Ill agree that load travels to stiffness, but this means that more load transfers from the inside to the outside at the axle line with the greatest stiffness, being a combination of suspension rate and chassis stiffness at / near that axle line, and less so at the axle line with less stiffness. I suspect you are imagining more stress increase than actually exists. The load seen by the chassis as a whole is the difference in the rates at each axle line, not the total of the two loadings seen at both axle lines.
A stiffer chassis is better able to resist the difference in loadings seen at each axle line, and as such more effectively isolates the weight transfer occurring at the rear from the weight transfer occurring at the rear.
This means that stiffening the rear of the chassis as well as stiffening the rear suspension will cause an increased weight transfer at the rear end of the car (with a resulting lesser transfer at the front, assuming lateral acceleration remains constant). In both cases this will result in more IR unloading, not a reduction in one case and an increase in another.
Try thinking of localised chassis softness as part of the suspension rate, e.g. if the rear of the chassis is soft then this adds to the overall softness at the rear of the car, being a sum of the suspension rate and the rear chassis stiffness.
Originally posted by GreenMadnessyou lift a wheel...to keep the body as straight as possible,
Originally posted by GreenMadnessthis cant be done due to the weakness of your passenger compartment... the only way to acheive the body strength needed to stay straigh and lift a wheel is with a roll cage.
Its not the twist itself that limits the ability of a softer chassis to lift an inside wheel, but the affect on relative front / rear roll stiffness of the softer chassis, i.e. a softer chassis cant as effectively isolate the front roll stiffness from the rear roll stiffness, so even if the ARB and spring rates are relatively high at one compared to the other some of this relative difference in roll stiffness is lost in the soft chassis, so the car is less able to effectively unload a particular inside wheel.
The passenger compartment will typically be the stiffest part of the total structure, simply due to its girth (i.e. its analogous to a large diameter square tube, being more rigid than a smaller diameter tube). Some of course arent very stiff, less stiff with longer wheelbase, more door apertures and with poorer design. The front of the chassis tends to be less stiff because its smaller and usually missing structural parts required to close the box, i.e. the lack of a structural member between the strut towers deducts a lot of stiffness, and ideally there should also be a diagonal brace here as well, but the engine tends to be problematic in this regard. The rear of the chassis suffers similarly, i.e. lack of bracing between the struts, and a lack of diagonal bracing. These are things that something can be done about. This does mean more of the loading will be seen in the central section of the chassis, but most can cope quite easily even if this means a slight increase in flex in the central part. Keep in mind that any increased flex in the central part of the chassis wont be the same degree of flex that would have occurred in the softer section before it was stiffened simply moved into the central section, it will be less.
Note that chassis stiffness is cumulative, each bit adding stiffness to the chassis as a whole.
I agree that the best way to increase body rigidity is to use a properly engineered cage that will include bracing between the strut towers, or be used in addition to such braces, but anything you do to increase stiffness will beneficial. You dont need to actually lift the IR off the deck for there to be an advantageous increase in rear weight transfer, anything you do to increase rear weight transfer (whether or not this actually results in daylight under the IR) will decrease understeer tendencies and probably sharpen responsiveness.
Seems I've done it again, exceeded the limit on verbose responses that is!
Part two below;Regards from Oz,
John.
Part two (sigh);
Originally posted by GreenMadnessNo 1 part of a race car is gonna work out like you think on your street car. all together as a package they do well.
Everything that Ive done to increase the chassis stiffness on my car has been noticeably beneficial to handling, responsiveness, and a general feeling of the car being connected to the road. Id fit a roll cage too if I could afford it and live with it (and if a proper cage were legal).
Originally posted by GreenMadnessMuch of the information seems to be a mix of mechanics, and RWD race car setup... although there isn't alot of information in the US for FWD race setup there is some, and most of it only states that RWD setups dont work...
Originally posted by GreenMadnessand the set up/ technique for driving a FWD car varys with every modification/ driver/ Manufacture.
Originally posted by GreenMadnessSO PLEASE in a quest for stiffness dont destroy your car... rear end roll in a FWD street car is favorable in comparison to a RWD RACE car.
If you have low roll stiffness in the rear end of any FWD car you will have substantial understeer because the IR wont unload enough, and the IF will unload too much (also causing traction issues on acceleration out of corners). If you want an understeering road car then your comment is correct, and is why the car manufacturers almost universally set up their road cars with too little rear roll stiffness, i.e. so inexpert drivers dont get themselves into trouble with oversteer.
Originally posted by GreenMadnessLASTLY... stiffness is good for racing, not gonna lie... i see RWD mustangs lifting the inside front tire on acceleration... and i see FWD civic hatches lifting the inside rear wheel on braking... but only on a race track!
Originally posted by GreenMadnesshonda's last cause they designed them well, meaing low stresses and high design factors. in impact loading (sudden loads) stiffness increases stress ALOT! so as you are stiffing your car you are in fact reducing its life... Race cars dont last to 200,000 miles.....
I dont dispute that increasing a localised stiffness in the chassis will to some degree transfer more load to some other part of the chassis and in theory could find a weak point that suffers as a result, but equally that part of the chassis that was previously flexing could fail as a result of the continued flexing.
In reality nearly all chassis are going to be able to cope with localised structural improvements without adversely affecting any other part of the structure, like you said they are well designed to cope with stresses without breaking. This will especially be the case if the car isnt habitually driven at speed over rough roads. I have to say my CB7 has been driven over rough roads for the last few years with no noticeable increase in the number of rattles etc and still handles as well as it did since any modification to its structure, and Im on Koni yellows at near full stiff front and rear.
Stiffening the suspension substantially is likely to impose far more stress on a chassis than stiffening the chassis itself. Porsches are well designed and far stiffer than the average Honda, they last a long long time.Regards from Oz,
John.
Originally posted by johnlI would, but I'm not really set up with the correct gear, I'd have to borrow a camera, then learn how to get the shots into the computer and then how to upload to the site, and I'm too lazy!
would something like this would work? They dont make shit for a CB/CD chassis but anything is better than nothing.
http://www.emracing.com/products.html
TRIANGULATED TRUNK BAR
TRUNK WALL BRACE
TRUNK FLOOR BRACE
ok ... first off... what you responded with was what i was trying to say in the first place... but far to busy to actually take the time to type out which i thank you for.
Second, as a person that understands what you said, and already knew it, i know that there are some fundamentals behind your logic, that if others did not have, could cause a good amount of MISUNDERSTANDING... to others
I understood what you wrote although from the books i have, about half of it is from my RWD racing book, and the other half is from my FWD racing book.
In reference to you attacking my stiffness claims...
i was copy pasting to make this statment and fucked it up good
for cars the body roll is the suspension giving (its meant to) when you stiffen the suspension you reduce body roll
the 2 brothers that raced a Mugen Acura Integra in the early 80's had two vey diffrent setups but could run the same times... it was found that the rear set was the big diffrence in how they drove the car, the conclusion was that unlike RWD where the rear set up is more important than front, because front only needed to turn... now almost all the importance was in front set up and little more than stability control for each individual driver was needed in the rear as long as the car/suspension was correct for the track and able to lift the inside tire, why the rear end is just along for the ride.
To clarify, i work at a race track, and see people that read info likethis, put braces and thick ass roll bars on there car... or evo IIIV's with huge roll bars and spherical bushings that are getting passed by a stock 90's audi quattro... with full leather interior and no mods and tons of body roll.
they hit the track and get horrible traction and when they turn it looks like the body wants to kill itself, because the chassis stiffness has not been brough up to par. thats the point i wanted to make that you tore up, all theses things are only effective if the car as a WHOLE is set up to take advantage of it....
NO OFF THE SHELF GROCERY GETTER IS... you said it yourself. so why are you giving out information on race car chassis set up and stiffining and racing suspension.
I was trying to say that race cars take a heavy amount of abuse because of the stiffness... if you are familar with the calculations in stress analysis for impact loading do them, the stiffer something is the more the equivilant static force is.Last edited by GreenMadness; 01-16-2008, 10:03 PM.Engines hate me... thats why they commit suicide
I am designing the suspension system for my school Formula SAE car, and I have never heard of intentionally lifting the rear wheel to offer better turn in. If anything, a lifted rear wheel means the rear sway resistance is too high for the application and should be lowered.
correct me if I'm wrong.DEVOTE
FS: Lokuputha's Stuff
