project h24
    project h24
    whats up peeps havent been on for a while i'v been working night and day to get my motor built i should have it back by next month the way its looking.
    for the the bottom it will be a completely balenced with balance shafts removed
    89mm pistons 12.1 compresson
    eagle rods
    toga oil pump and gasket kit
    darton sleeves
    UR pully
    greddy timing belt
    moroso oil pan
    manual tension
    for the head
    4 angle valve job
    port and polish
    skunk2 valve train
    hi comp valves
    stage2 cams
    cam gears
    skunk2 intake mani and TB
    topfuel intake
    hondata gasket
    geddy header
    carsound cat
    2.5 custom pipe hks muffler
    wit hondata s200
    let me know how this sounds to you give me al input thanks
    U dont work U dont eat
    U dont grind Udont shine
    1st car 90 CB7 lx auto coupe
    present car 90 CB7 ex clutch coupe
    1st motor f22a1 2nd motor f22a4 present motor JDM H22a with m2b4 trans
    Nice !!! pics please !!!
    Big 16g Turbo/H23 Head Swap/TSX Projectors
      what platform? H22 im guessing? What's your stroke gona be?
      with only the pistons being 89, you'll get to be 2.26l.
        whered you find the toga oil pump?
          will you be increasing the stroke?...if so how...sounds interesting
          DEVOTE
          FS: Lokuputha's Stuff
            a friend and i are gonna try to use the f22 crank i think it increase the stroke to about 96mm and rods if that dont work out i guess it will stay a 2.2
            and mike u can get the toga oil pump from http://www.importperformanceparts.net/ i think its around 250
            now i just picked up a fidanza flywheel and exedy stage2 clutch and steel braided clutch line for my m2b4 cant wait to get it runin
              f22 stroke is 95. that would put you at a small 2.3, and 96 will put you at 2.38. You should try an f23 crank.
              what rods are you using?
                F22 crank is 95mm. With your 89mm x 95mm crank will net you a 2.364L engine. If you source a crank from the F23 which is 97mm you can bump it up to 2.419L.
                  Smart guy...I actually went and calculated it.
                  To OP, where did you get eagle rods from? They don't do F22/23 rod length's unless you go custom.
                    thanks for the help at the time im trying both rods see witch ones would fit better but i did here of someone using the h22 rods if thats the case im gonna just order eagle rods for the h crank. yeah but as soon as i figure what rods to use i can start building the bottom.
                    there was another company that make rods for the f22/23 but they were about 500$ im gonna hold back unless i really have to go that route
                      This link should be of some interest to you. Rod Fortifying explained
                        If I were you I would use an H22 crank and get the journals grinded to stroke it to 96 or 97 ( or what ever you are going for). Maybe even a 98+ crank ( 55mm mains) in an F23 block ( sorry not sure if you were using an F or H series block) and some custom B series rods which will be cheaper than F/H custom ones.
                        There is alot of info on the H22 vs H23/F22/F23 crank on Honda Tech.
                        Life is wide, limitless. There is no border, no frontier ~ Bruce
                        My Page!
                          the easiest route would be to do an f23/h22.
                          Look into scat cranks.
                            The toga oil pumps for h22/h23 are on serious back order, I was told two-three months last time I checked so I just went with a new oem pump.
                            Turbo H23a3 build has begun
                            01-01-2019
                              There are services available where you can have the OEM oil pump rebuilt into a high volume pump.
                              My friend at the shop told me there are no H22/23 toga parts anymore. THe only parts toga have for our engine is the Flywheel and clutch. The K series took over.
