When I started collecting parts for my build last year, I started off by buying a used F22A Bisimoto header. Never been used, ceramic coated, and I got it for $550. What a great deal, right?
Now my build is almost done - time for the header and exhaust. Except I can't get the two parts to go together. The most the primary and collector will overlap is about a half inch, which is about 1" from the end of the tubing in the collector. Here are two pictures, which show why the tubes aren't going together - the pipes in the collector are straight, but not in the primary:
I am well aware of the leakage problem with the Bisimoto header - I have read all of the old posts. On the other hand, I was really hoping for some gains at higher rpm, and only the Bisimoto header seems to be able to do this. So, I am asking for suggestions from the experts:
1) With the primary and collector pushed together a half inch, the gaps aren't too bad. Would it be better to leave it at a half inch or would it be better to try to force it together more (for example, using turnbuckle hooks)?
2) Is this a lost cause and should I just go buy a different header?
3) I know of three other header choices. Is any of these headers significantly better or worse than the others?
a) DC Sports
b) Generic ebay header
c) F22A4 header
4) Are there any other header options besides Bisimoto that would flow well at higher rpm?
a) DC Sports
c) F22A4 header
