Fitting an Innercooler...
    Does anyone on here have a turbo setup on their CB7 with a stock bumper? I'm getting close to boosting my car and i can't see how an innercooler would fit without cutting out the entire front and having the IC sticking out 10 feet.
    Pictures would be helpful along with suggestions?
    ive got a 90-91 bumper thats been modded a little with a jonny race car IC... custom brakets are a definate. theres not much room at all behind mine, but thats due to the fact of how long it is. a shorter, but taller one would fit better, since you could cut a peice out of the bumper support to accomidate the hight, and no one would ever know.
    instagram @mikeymeyagi
      his fitting looks ridiculously good ^^^
      Mine, yeah I didn't really care, i just hacked away and stuck it in, I need to get it further back but the tranny lines are in the way. I also had to relocate the ps cooler lines. Custom brackets are a must
      Shift_BOOST
      BOOM!
        we did some hacking to make mine fit but i dont have a stock bumper here are so fitment pics
          oh yea, i didnt mention before, i threw those PS cooler lines away, which frees up alot of room. just connect the two lines together with a peice of hose, and everything will work fine.
            I had to do a lot of cutting to get mine to fit, including cutting the bumper itself... Mines a 3.5" thick core...
            12.5 at 114.6mph 15psi
            11.7 and 11.5 20.5psi
            F22a1
            60-1 td06h turbo
            Darton mid sleeves
            85.5 wiseco 8.8:1 forged pistons
            Crower pro billet rods
            Custom ported head.
            KMS valves
            F23 headgasket
            ARP H23 headstuds
            H23 upper intake manifold
            F22a6 lower intake manifold
            Intake manifold is gutted
            AEM EMS 1040u
            FIC 850cc injectors
            Walbro 255 pump
            H23 manual trans
            Prelude shifter assembly
            Forbidden short throw
            Nitrous Express Kit installed, never used on this motor
              o-t, but lowdollar all your sig stuff is really funny
                so those two thick lines in frount of the radiator in the air damb is the p/s cooler?
                i was gana mount my ic in front of that some how...
                but are u saying u dont need it?....I can just connet the two lines that feed to that together w/o the cooler? or am i reading it wrong
                Old Ride-New Ride
                  i had to hack the bottom of the bumper for the cold side, cut about 70% of the bumper reinforcement. and relocated the p/s lines into the radiator
                    Accord SIR has a nice setup.
                    600HP" 1990 ACCORD LX COUPE COMING SOON
                    CLICK HERE TO VIEW MY 1990 CB7
                      no you dont need the P/S cooler... people remove the cooler and loop the lines together without problems, but if youre concerned, oneoffaccord had a nifty idea... loop the p/s lines into the bottom of the radiator, the part for auto tranny fluid, and use that for cooling
                        Im guessing if you were to run the P/S lines to the bottom of the rad. you would have to get a seperate cooler for the trans?
                        92 DA9 // 93 D21 4x4 // 92 CB7
                          ^^ only if you have an auto trans
                          the p/s cooler lines are optional....think about how much steering you would have to do to make the fluid hot enough to need a cooler.
                            Or you can ditch P/S completely. I was focused on how to get an intercooler to fit on a cb with OEM fogs. I considering using a longer bolt for the bumper bracket. The two bolts that hold the bumper down at the top that are held on by nuts. I was planning on somehow extending it so the bumper would stick out more, but it just looks retarted lol.
                              thats gonna be a mad tight fit bro
