Tranny Cooler
they sell them at autozone for about the same price, two of my CB's have them installed. i always figured they were easier to install than to bother finding non-rusted fittings and lines for the bottom of the radiator. also having it out on its own makes it easier to remove the radiator.
i usually stick it in front of the radiator behind the vertical bar that holds the hood latch, it holds it snug against the front of the radiator.
theres two lines coming from the top/front of the transmission. use the new hoses that come with the cooler and run both right from the tranny to the cooler. thats it.
[img]http://www.****.com/pics/trannycooler.jpg[/img]
Bringing up a thread formn the dead Quick question? The transmission lines are hooked up to the condensor or radiator?If it is the condensor then you could just remove it right, I already have my compresor out so no A/C.What else Could I take out that uses only the A/C, I still whant the heater?Thanks
