hello everyone. i was curious what would be better for my car: P28 or P06? I have h22a, S/R intake, complete exshaust system, pulleys, scunk2 stage 1 cams and adj. cam gears. i am a newbe to chipped ECU and stuff like that so any help would be gratly appreciated. Thanks
p28 or p06?
p06 is from the nonvtec civics, p28 is from the vtec's... both work well when being chipped for f22's/h22's, but you need to pick based on whether ur motor has vtec.
youre running an h22, so youd want a P28. the nonvtec turbo F22 dudes like to use p06's because they are cheaper and work just as well as a p28, minus vtec.
a lot of places will add VTEC capability to your non-VTEC ecu for free. I have a phearable.net ECU, i highly reccomend him,H.S.A.E.
90 CRX Si - gutted, caged, Bisi F2d kit, close ratio LSD trans, F22A6 - under construction
99 civic LX - y8 head and trans, lowered, blowing cold AC, and getting 35mpg.
i would go with the p28 cuz it doesnt have a knock sensor( which is GOOD and BAD) Good part is that the computer doesnt know if you have a knock so therefore your timing wont retarded under full throttle.
The Bad part is that you wont know if you have a knock.so therefore the timing will not retard. but the computer will know if you have that in your computer (knock sensor control) and it doesnt control the dual stage runners.
the duel runners can be controlled by the vacum, which is how I have it setup, got the idea from juan. Works great!
Anyone know where else to get a chipped P28 with a base h22a fuel map?2DAO (2 Door Accord Owner)
JDM H22 DOHC 200/161 2.2L
My members ride: http://www.cb7tuner.com/vbb/showthread.php?t=20385
