i spoke to Larry Widmer today at the sema show, and got to check out the hardend rocker arms for the H motors. the are 4pts harder on the rockwell scale then factory, and manufactured to Larry's strict specs and tolerances. Larry forsees them being availible in december, with a price under $500 for the entire set.
if your having rocker arm wear issues due to stiff aftermarket valve springs, you should check these out.
he also had his B seires and K seires aftermarket, pre ported heads on display.. the quality of workmanship is phenominal, the porting in the head is a big step up from stock, and a complete B seires head with all Larry's prefered valves/springs/retainers etc is set to retail for $900. a bare head is availible for $500.
Endyn if you ever get a chance to speak with Larry, hes a down to earth guy, who really cares about the people that do business with him, and the work he does for them. "i treat every engine i build as if it were my own"
