My anttenna wont go down with my JVC radio. Is there any way to fix this so it goes up and down like it did with the stock radio.
Anttenna wont go down w/JVC radio.
i dont know much about car stereos and the such, but i know the antenna always gets +12 and ground and a third wire thats +12v when the radio is on, nothing when its off... so if somethings wrong w/ the antenna wire on his deck, maybe he could hook up the remote amp turn-on wire to the antenna instead (unless the turn-on wire is only momentary or some other voltage... idk)
I haven't been here for a while, I hope I'm not too late! JVC decks only have one trigger wire. You use the same blue wire (remote turn on) for an amplifier for your antenna. Most other aftermarket brands have independent wires for antenna & amps.CAI soundz so good........
But not as good as a full Eclipse Sound system
www.clubaccordquebec.com
