rust, not as bad but leaks suck 56k no no
    So my 91 white accord that i purchased a couple of months ago, i knew there was a leak but thought nothing of it. Today i decided to tackle it when i saw a few rust spots. i took apart the interior of the trunk and ran a hose outside, to find all the water going into the trunk heheh.
    the tail lights were leaking, the upper seal was leaking around the trunk, the main seal around the window moldings were leaking as well.
    this is a good DIY to start out with http://www.cb7tuner.com/vbb/showthre...hlight=leaking
    what i had to start with after taking off the weather stripping
    ...notice the rust spots and i already removed the window modlings which were a pain.
    main leak
    sanded it down a bit to kill some of the rust
    side upper pannel, this one was really bad but after a bit of sanding it worked out....
    primed and prepped
    do you see any more rust?
    i also siliconed the tail lights as well hehehe. tomorrow ill check for leaks again. I feel pretty good about this, also my car isnt in a snow area like some people on this forum and they would love to see almost no rust like mine lol!
    thanks for looking.
    Retro!
    Hater
    no, because you painted over it, it will come back. the rust pits the metal and if you don't get it all back to metal, rust returns. later.
    Avoiding dirt at all costs
      werd. Unless you sand the rust away completely, it will return. Duh!
      Get a wire brush attachment for the dremel and have some fun!
        also naval jelly dissolves rust, if you give it a good 12 hours to sit (keep applying fresh coats) it dissolves a lot of the remainder... like everybody said, the tiny pits are what makes it come back, try to sand all of them out...
          OH i sanded all the rust off lol...i just showed pictures of the parts before i actually painted. haha if i didnt sand the rust off all the way i might as well just leave it be. heheh.
          Retro!
          Hater
            ok guys dont use cheap ass rubberised latex all purpose silicone caulk. it was still leaking at the window and i noticed that after a few days the silicone cault was too flexable and leaked...but this time around i figured out how to get the window molding down better =).
            i went to the store and bought construction adhesive, pros....good stick...cons....haha no turning back!
            im in the process of re-doing it right now.
            Retro!
            Hater
